Air/Fuel Ratio Gauge
Old May 22, 2006 | 10:52 AM
Evil 8's Avatar
TwIsTeD KrE8iOnS
Was wondering if anyone knew which wire on the o2 sensor i connect to the air/fuel ratio gauge. The wire is located right behind the air intake manifold. Its a grey connector with four wires.
Old May 22, 2006 | 11:31 AM
You can't hook up a normal "A/F" guage on this car. It uses a WBo2 sensor that outputs current insted of voltage. I supposed you could hook it up to the post CAT narrowband.....but what good is that
You should put in a stand alone WBO2 that will give you values that mean something
Old May 23, 2006 | 01:21 PM
Evil 8's Avatar
TwIsTeD KrE8iOnS
oh. That sucks cause i was able to do it on my mazda 6. oh well. thanks
Old May 23, 2006 | 05:52 PM
You can hook it up to the narrowband...but like most of those guages they don't give you great data
Old May 24, 2006 | 02:02 PM
Evil 8's Avatar
TwIsTeD KrE8iOnS
do you know which wire that would be. Anyone out there have a diagram????
Old May 24, 2006 | 03:44 PM
MazdaManiac's Avatar
The entire shop manual is on my site, but here is the wire labled on the PCM loom.
However, the info you gather from the rear O2S is useless, unless you are just concerned with your emissions efficiency.
Attached Thumbnails Air/Fuel Ratio Gauge-iviewcapture_date_24_05_2006_time_13_37_39.jpg
Old May 25, 2006 | 09:50 AM
Evil 8's Avatar
TwIsTeD KrE8iOnS
Thank You
cliffkemp
Dec 24, 2024 10:48 AM
yurcivicsux
192
Sep 12, 2017 10:54 PM
JantzenRX-8
Oct 4, 2015 11:30 PM
