Water in Tail light
Old May 17, 2006 | 04:18 PM
Rootski's Avatar
DGAF
Water in Tail light
After about a weeks worth of rain here in Ohio, I decided to give my 8 a bath. Before I even touched water to the car, I noticed a huge amount of condensation inside the rear passenger tail light, so much that the whole thing was nearly obscured. It's never leaked before, and all the lights inside still work fine, but it looks like hell! Is there any way to fix this?
Old May 17, 2006 | 04:31 PM
NgoRX8's Avatar
take it to the dealer and show them. it should be a replacement under warranty.
Old May 17, 2006 | 05:26 PM
N rider89's Avatar
^NieL
yeah warranty work for sure.
Old May 17, 2006 | 05:45 PM
Rootski's Avatar
DGAF
God I hate the dealers.
Old May 17, 2006 | 07:59 PM
tejon's Avatar
I had a tail light assembly replaced for condesation problem under warrenty without any hassle. I just showed it to the dealer and they replaced it with a new one - no questions. Your situation is not unique, there is a discussion about it else where on the forum.
Old May 17, 2006 | 08:01 PM
NgoRX8's Avatar
I hate dealers too... my headlights have condensation, but i've been stalling to get it replaced because i don't wanna have to swap my bumper. No way do i want the dealer to take off my aftermarket bumper.
Old May 17, 2006 | 08:06 PM
Brettus's Avatar
Boosted Kiwi
I drilled two small (approx. 1.5mm ) holes in the bottom of mine & the problem went away
you cant see the holes unless you are looking for them.
Old May 21, 2006 | 04:07 PM
Crazy Rx-8 Driver's Avatar
XYELLR8
the bottom of your rear tailiights or the fronts? i'm assuming the rears and you drilled them from the back right?
Old May 22, 2006 | 11:05 AM
msrecant's Avatar
Hubble has been saved!
Known issue that Mazda fixes under warranty. Check out https://www.rx8club.com/series-i-trouble-shooting-95/tail-light-water-62150/ .
Old May 22, 2006 | 09:42 PM
poorman's Avatar
warranty it. If u drill the holes you will sometimes still get moisture in ther but no pooling, and if u drill the holes, they might void the tail light warranty lol.
When i got my water in tail lights, i had like a cup full of water in them lol
Old May 22, 2006 | 10:12 PM
My left tail light had water in it b4, it was like maybe 2 cups of water in it.
Replaced under warranty, its a known issue, no questions asked.
if you drill holes, condensation will come back one day. especially rainy days. and, you will not get any warranty cuz "you drilled the holes and no it does not going to look like its a factory defect"
Old Oct 15, 2009 | 07:02 PM
rx2kill's Avatar
wanting another rotary
Wow too many ppl relying on warranty what about the ppl out of warranty??
Old Oct 15, 2009 | 07:07 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Well.....you can drill holes as some will do(but I won't), or you can go get a gasket and do it yourself.
http://www.finishlineperformance.com...cat=302&page=1
If you get that far and see the gasket, be sure to click on "WATER IN REAR COMBINATION LIGHT" to see how and what to do!
If you do a search, there are many threads on this subject.
Old Oct 16, 2009 | 07:24 AM
Ralker's Avatar
I just fixed the gasket recently on my 04: screwdriver, silicone sealant, a small hairdryer and about thirty minutes of effort on my part. It's been about a month now and no new water .
Old Oct 17, 2009 | 09:40 AM
rx2kill's Avatar
haha yea a $54 gasket, damn thats expensive, im not rebuilind a top end on e dirt bike lol. Yea Imma try the silicone approach and c how that plays out, good and bad thing is florida prolly wont rain for a few months from by the time I do it, alright anyways thanx
Old Oct 17, 2009 | 10:00 AM
lepichichi's Avatar
I LuV mY Rotary....
i used cilicone and problem solve
Old Oct 17, 2009 | 10:22 AM
You will have to let the light dry out though. I removed mine, removed the connectors and rinse the housing out with filtered water (so no spots are left) and then let it sit in the sun for a few hours.
When you remove it you will see the water line on the gasket. After the light is dried out just run a bead of black RTV along the factory gasket (after you clean it up of course) and a bead along the body where the tail light goes (you will see the outline of the gasket) and it will never leak again.
Old Oct 17, 2009 | 08:47 PM
mkmike103's Avatar
+1 on removing, cleaning, drying and siliconing the hell out of it. Weird thing for me was the first couple rains after, I still got condensation so I figured it didn't work. After that, it rained a bunch here and its dry as a bone, so I consider it a success.
Old Oct 20, 2009 | 03:14 PM
corners's Avatar
An RX ate my baby
Mine's at the dealer getting fixed right now. They said there's an upgraded gasket kit for the lights available now. They don't replace the whole assembly any more.
Old Oct 20, 2009 | 03:36 PM
TX
Upgraded gasket my ***. They work as well as the upgraded visors. I have had two of the upgraded gaskets and finally did my own upgrade. A new gasket and black RTV would be the best solution.
Old Oct 21, 2009 | 03:00 PM
Shijin-Kun's Avatar
Rotary Power!
i had about half the taillight of water. It was so much water that it fried my brake light. I removed it poured out the water and then used a hair dryer to dry it. Warning!!! do not use the hair dryer for a long period of time because it will melt the plastic. I drilled 3 holes at the bottom of the taillight. At first there was condensation then after a day it went away.
Old Oct 21, 2009 | 06:39 PM
rx2kill's Avatar
The dealer told me im way outta warranty , not a surprise, it was up in 07, a lil waters not all that bad..... Lame, I cant see myself getting a 54 dollar gasket for a light, maybe im crazy. What is RTV?
Old Oct 21, 2009 | 07:33 PM
Old Oct 22, 2009 | 08:53 AM
adamwzl's Avatar
<3's Bunnies
I have a passenger tailight brand new I can sell you... fits 04-08 models.
Old Oct 22, 2009 | 07:09 PM
Tamas's Avatar
Registered Lunatic
If you use the silicone sealant, can you still remove the tail light if necessary? I mean, using the sealant between the car's body and the gasket acts like an adhesive, no?
