Old bird battery died today
Old May 12, 2006 | 01:26 AM
Fab 8's Avatar
After exactly 2 years 9 months of ownership, my battery has given up. Couple of slow groaning cranks, and that was it.
So now I need to get a replacement battery - anyone can recommend where I can get it changed, and which brand is best? Many thanks.
Old May 12, 2006 | 04:02 AM
mkl22's Avatar
try panasonic, I usually change batts at nam wah which is at paya ubi 2nd floor. they are the agents for panasonic, Amaron and hoppeke(or soemthing like that). open 7days a week. as they supply AAS also. try to get a maintenance battery as you can add water to prevent the battery from drying out due to the hotter temps in the RX8 engine bay. I just did a load test and found the original batt still good. get them to do a load test to make sure the batt is dying.
Old May 12, 2006 | 05:42 AM
CruiseGuy's Avatar
Died of Birdie Flu...
Old May 12, 2006 | 10:15 AM
airspeed's Avatar
Velocity REight
Why not a maintenance free battery which is sealed and don't need topping up?
Wouldn't it be better in hotter temp area? Cos I was thinking of getting that one...
Old May 12, 2006 | 11:14 AM
Emperor's Avatar
aka Spectre
Thats why. Must check battery once in a while around 1 or 1.5 years of getting the car. A battery usually last approx 2-3 years depending on battery and usage. And our hot humid weather actually shortens the life abit more.
Imagine you are in a rush and car cannot start.
Old May 12, 2006 | 11:37 AM
morganoh's Avatar
I wanted to change to a Dry cell as well. But one bad experience change my mind.
me and my uncle just alight from his car and after walking for 5 meter.
Some thing with in the car exploded.
After opening the car bonnet, found out that the dry cell had exploded ..
Was told that this will only happen on Dry Cell not on the normal Wet batt.
and not much diff in performance between a Dry and Wet Cell.
So in the end me decided only to use Wet Cell, just make sure to top up with batt water everytime I service the car (every 5000 km)
Old May 12, 2006 | 09:09 PM
Fab 8's Avatar
Thanks for suggestions. Went to autobacs to pick up a varta. Didnt know the varta is pretty heavy - 18kg compared to about 16kg for the original panasonic one. At least the starting is now faster, compared to when the car was new.
Old May 12, 2006 | 11:30 PM
mkl22's Avatar
read this:
http://www.uuhome.de/william.darden/
one of the most conprehensive info on battery.
Old May 13, 2006 | 01:15 AM
sqflyer's Avatar
Heavy Machinery Operator
Wow... talk about information overload!
OnebaddRx8
Aug 25, 2019 11:34 PM
Danield97
Oct 10, 2015 05:58 PM
Tweaked Tay
Sep 25, 2015 07:54 AM
