I Need A Wire Diagram
Old May 9, 2006 | 03:54 PM
NeoJay's Avatar
ZOOM-ZOOM-ZOOM
hey new to the site just got my 04 titanium gray 6 speed rx-8 i have a nice alarm system for the car that i would like to install wondering if there is a wire diagram on here or do i need to run down a book.
I'm looking for the wiring into the power door locks and actuators also looking for parking lights ignition trunk release brake lights i think that about covers it lol well if anyone can help PM me thanks for you time.
Old May 9, 2006 | 04:05 PM
lurch519's Avatar
www.evoperform.com
12volts yellow (15A) + ignition harness
Starter white/blue + ignition harness
Second Starter N/A
Ignition black/yellow + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory blue/green + ignition harness
Second Accessory white/red + ignition harness
Keysense pink/black + ignition harness
Notes: Also found at the keyless control module above the passenger side kick panel.
Power Lock lt. green - driver kick, door harness
Notes: Lock is negative trigger thru a 1,000 ohm resistor. Unlock is a straight negative trigger. MUST use relays.
Power Unlock same as power lock wire
Lock Motor red/blue 5wi driver kick, door harness
Unlock Motor red/black 5wi driver kick, door harness
Parking Lights+ black/red + driver kick, harness to rear
Parking Lights- lt. green - headlight switch
Hazards orange - hazard switch
Turn Signal(L) green/yellow + turn signal switch
Turn Signal(R) black/red + turn signal switch
Reverse Light red/yellow + driver kick, harness to rear
Door Trigger black/blue - driver kick, harness to rear
Dome Supervision green/black - driver kick, harness to rear
Trunk/Hatch Pin brown - driver kick, harness to rear
Hood Pin purple/white - pin switch under hood
Trunk/Hatch Release yellow - release switch
Power Sliding Door N/A
Factory Alarm Arm green/red - driver kick, door harness
Notes: Arm is negative trigger thru a 1,000 ohm resistor. Disarm is a straight negative trigger. MUST use relays.
Factory Alarm Disarm same as factory alarm arm wire
Disarm No Unlock
Tachometer NOT blk/wht, blk, or wht/blue ac any ignition coil or fuel injector
Wait to start N/A
Brake Wire black/blue + brake pedal switch
Notes: Can also use black/yellow (+) in the driver kick, harness to rear.
Parking Brake gray - parking brake switch
Horn Trigger green/blue to green/orange - horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Alternate Part1 #: 556UW
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Old May 10, 2006 | 12:17 AM
NeoJay's Avatar
ZOOM-ZOOM-ZOOM
sweet thanks gonna get to work tomorrow
Old May 15, 2006 | 02:23 AM
Chamberlin's Avatar
2005 Ti Gray RX-8 - SOLD
Angry thanks too
Just got my 2005 Titanium Gray RX-8 on friday, and this is my very first Mazda anything post on any forum!
Anyways, the car is in pretty good shape all around, even though it had 29K on it.
It was built in 9/04 so I assume it was an early 2005 modle/sale.
The only thing I am really bummed about, is that the dealer I got the car from had one of those gay *** KARR alarms on it, that I certainly didn't want to buy, and they had a tech com out to rip the thing out before I drove it home...
Holy crap did they make a fricking mess of the kick panel wiring harness... I am actually suprised the car even runs...
I am eventually going to put a CarPc in it, and I am sure I will be tapping into these same wires at some point myself, but the wiring codes posted above will sure help out trying to make sense of what they hacked on the fuse panel..thnx... I still can't believe they totally made spaghetti mess out of a brand new RX-8. What are these dealers thinking?
-C
tjohnmeyer
Sep 28, 2017 05:03 PM
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
jer2911
Sep 29, 2015 06:37 PM
Learners_Permit
Sep 27, 2015 07:38 PM
