Rough Idle/Stalling
Old Apr 25, 2006 | 08:52 AM
Tirminyl's Avatar
Listen to Zoom44
Rough Idle/Stalling
On my way to training this morning, I was sitting at the stop light. I then felt vibration caused by a rough idle and then the car stalled, almost killing its self. I tapped the throttle and the rpm's dropped back to stalling point in which I revved the car again. For the next few minutes of driving the car seemed and idle'd fine. I purchased my car used, it has 19,5xx miles, all latest updates (battery, starter, etc) as of late January. The only difference since then and now is that I have a green filter and I just filled up at the BP yesterday (first time for 93oct). If fuel, filter, or flash are not issues, what could be?
I am out of town so I am not sure if a stop to a unknown dealer would do me good if they can't reproduce the problem.
Old Apr 27, 2006 | 11:49 AM
Rough Idle could be alot of things. Broken Apex Seals, Not enough Oil, Wrong kind of Oil, weak battery. etc
You should check your airfilter for dirt. 8 needs quite alot of fresh air and if your 8 has 19K miles. Maybe u should change it.
Old Apr 27, 2006 | 04:37 PM
Go48's Avatar
Since you just filled up, it could be water or other contamination in the fuel. Use up this tankful and refill at another station. If it still wants to stall, take it in to a dealer for diagnosis and repair.
Old Apr 27, 2006 | 05:13 PM
mysql101's Avatar
rough idle can also be caused by bad motor mounts. A number of people are seeing them melt away. Have your dealership check them.
Old Apr 27, 2006 | 08:01 PM
Tirminyl's Avatar
Listen to Zoom44
Thanks guys. No issues since that one time. the rough idle was right before it stalled.
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
DubbsLuvs8s
Sep 8, 2015 06:51 PM
