Questions about my new 06
Old Apr 17, 2006 | 10:23 PM
Xeres's Avatar
Question Questions about my new 06
Let me start out by saying I love this car, I’ve put almost a thousand miles on it already. So far it’s been everything I had hoped for. However being new to the RX-8 and rotary engines in general I had a few questions for you guys. When shifting into gears 1-3 an occasional loud thump can be heard. Also during hard acceleration at 7500 RPM the engine just seems to hang for a second before continuing on. Any comments or thoughts would be appreciated.
Here are some pics.
Attached Thumbnails Questions about my new 06-dsc01742a.jpg   Questions about my new 06-dsc01744a.jpg
Old Apr 17, 2006 | 11:01 PM
cleoent's Avatar
n00b
man that is sexy!!
7500 rpm thing might be normal, i dont know about the clunk from 1-3, why dont you have the dealer check it out?
Is that a shinka?
Old Apr 17, 2006 | 11:03 PM
Xeres's Avatar
No it's a VR with grand touring. Can anyone explain why the engine lags at 7500 RPM?
Old Apr 17, 2006 | 11:04 PM
NgoRX8's Avatar
its a velocity red. no shinka b-pillar.
can you explain the gear 1-3 shift problem? is it when you clutch in? when you shift? or what?
Old Apr 17, 2006 | 11:08 PM
Xeres's Avatar
It usually occurs when putting the car in gear at a stop when the engine is at idle. However it also can occur when shifting up into 2nd or 3rd.
Old Apr 17, 2006 | 11:12 PM
NgoRX8's Avatar
does it happen all the time?
Old Apr 17, 2006 | 11:16 PM
Xeres's Avatar
Not all the time.
Old Apr 17, 2006 | 11:17 PM
Raptor2k's Avatar
Club Marbles Member
Where does the thump come from? If it's the gearbox, it's normal while the transmission fluids are cold. Dunno about the lag, have your dealer check it out. Sometimes it takes a 'crunch' for me to get in 1st gear, and 2nd sometimes. Changing the transmission fluid to something better like Redline or Royal Purple would definitely help, I need to get that done.
Nice color choice, btw
Old Apr 17, 2006 | 11:25 PM
the ist gear clunk/thump is related to the tranny being cold but can happen even when warm. its just the synchros doing their job. changing to a better fluid as mentioned above will take care of it.
the hesitation can also be attributed to a cold engine. other causes could be fouled plugs, misfire etc. but generally those would cause a CEL.
Xeres's Avatar
I’ll start paying better attention, it might only make the noise when it’s cold. I'm really surprised about the lag, it just hangs for about 1/2 sec but it's really noticeable in the sound of the engine and the tach. I'll play around with it a little, try different gears see if that makes a difference.
Old Apr 17, 2006 | 11:46 PM
sunilseru's Avatar
I have the same issue when shifting from N-1 or 1-N-2. Mostly starts after I've driven 30 - 40 miles. And happens when the car is at rest. Will take it to the dealer some time.
Old Apr 18, 2006 | 05:52 AM
valpac's Avatar
Ahead of its time
Normal operation.
from http://www.rotaryengineillustrated.com/renesis.php
Variable Fresh Air Duct (FAD): The High Power specification engine mated to the six-speed manual transmission incorporates a variable fresh air duct in addition to a large, low resistance air cleaner. At about 7250 rpm, a shutter valve opens to shorten the intake manifold upstream of the air cleaner. The shutter valve works in tandem with the variable intake valve to boost torque and power at high engine speeds. The fresh air duct is partially inserted into the air cleaner and enables an optimal length intake system by valve opening/closing.
BTW, congrats on your new car. Beautiful color, too.
Old Apr 18, 2006 | 06:20 AM
Imidazole's Avatar
That tint has to be illegal in most states!
Old Apr 18, 2006 | 08:01 AM
raspyrx7's Avatar
the 7500 rpm is likely your last staged ports opening... has been seen on 6port rotary for long as I can remember.... its a time intensive tuning thing or just live with it thing... some may be more noticeable than others. Could also be a minor grounding issue... when those last injectors kick in with the ports it could cause a minor ground issue to be more substantial.
Old Apr 18, 2006 | 08:09 AM
Skythe's Avatar
Lascivious Post Whore
Mommy, what does VR mean?
Old Apr 18, 2006 | 08:25 AM
Raptor2k's Avatar
Club Marbles Member
^velocity red?
Old Apr 18, 2006 | 11:04 AM
cleoent's Avatar
n00b
The thump is normal.
7500 rpm just make sure you have the latest flashes.
FYI: The flat spot you may feel might be in your head because you are expecting some kind of vtec like boost, the rotary engine doesn't have that. It just pulls to redline very evenly.
Old Apr 18, 2006 | 04:07 PM
UFGator12's Avatar
TEBOW FOR HE15MAN
Yes, I have that same thud as well. It doesn't bother me though. I didn't really even notice it until right now.
Old Apr 18, 2006 | 04:37 PM
maisis00's Avatar
With exception to the tinted windows externally that is my car to a T.
I am debating whether or not to tint the windows. That does give me a nice look at the difference. Looks nice!!!
Old Apr 18, 2006 | 05:22 PM
hemanrulez's Avatar
It wasn't me!
Wast the last flash released in 05? His 06 should have all the new flashes direct from the factory.
Old Apr 18, 2006 | 07:59 PM
Xeres's Avatar
Yes it's illegal here in CA unfortunately. There was no thump today although it is about 15-20 degrees warmer today. I think you guys are right about the transmission being cold and causing the noise. I tried reving in different gears today and got some interesting results. Starting in 1st and shifting at 8000 to 2nd and then shifting at 8000 to 3rd the engine delivered a smooth increase in power the whole way. However already moving in 3rd and flooring the car, the RPM increased to about 6250 and then paused for about 3 seconds and then continued to 8000 at which point I shifted. WTF is that??? That doesn’t seem like normal engine operation. I had to hurry home so I didn’t have a chance to repeat with the same conditions. Maybe because the car is new I'm being paranoid but almost 3 sec lag doesn’t seem normal.
Old Apr 18, 2006 | 08:32 PM
mysql101's Avatar
RP will help out a lot more than RL for cold starts. RL was just as smooth once everything's going, but after switching to RP, it's smooth even before the fluids are warmed up. I'm going to be sticking with RP from now on...
Old Apr 18, 2006 | 08:34 PM
mysql101's Avatar
Originally Posted by Xeres
Not all the time.
Most new owners also complain about a loud thump sound when they start up the car and start it moving... but it doesn't sound like it if you're hearing it when you get up to 3rd gear.
Old Apr 18, 2006 | 08:37 PM
Xeres's Avatar
I plan on changing to Royal Purple this weekend.
Old Apr 18, 2006 | 11:09 PM
that sounds like a protection scheme. either engine overtemp or knock related(or both) probably knock. what grade fuel is in your tank? what company?
