My display went blank!
Old Apr 13, 2006 | 11:48 AM
DRIVINSIDEWAYS's Avatar
Las Vegas
Unhappy My display went blank!
I was dusting my dash and my display went blank. My towel had some static and shocked the display. The display lights up red, but none of the functions light up. Is this tepmerary or did I break something?
Old Apr 13, 2006 | 12:36 PM
Dro's Avatar
Dro
an excuse to speed ! brilliant !
Old Apr 13, 2006 | 06:37 PM
Las Vegas
Not that display. It's the center one for the audio and ac stuff.
Old Apr 13, 2006 | 06:40 PM
Nemesis8's Avatar
Bigus Rotus
Weird - maybe there is a fuse you could pull, but I left my book at work.
Old Apr 13, 2006 | 06:59 PM
Gomez's Avatar
Shifty Bastard.
Static electricity can't generate enough current to blow a fuse.....however it does generate thousands of volts, which will easily destroy a microchip.
This is the first time I've heard of this happening and I'm amazed it did......however I think the display is toast, unfortunately.
To the dealer with you for a warranty repair......
Old Apr 13, 2006 | 08:20 PM
pikachu's Avatar
If your warranty has expired, there just happens to be one on eBay for $5 right now
Old Apr 14, 2006 | 10:25 AM
Las Vegas
I am going to take it in today. A warning to the rest of you: Make sure your car is off while dusting the dash with a microfiber towel!!!
Old Apr 15, 2006 | 12:29 AM
The_Pendragon's Avatar
Where are my Hypno Rims?
My dash has also been F'ed up lately. Sometimes it won't light up for 5 mins after i've been driving. Or when it does light up right away, everything is lit up at once or completely scrambled and randomly blinks. The radio and cd controls still work fine, but the dash just doesn't want to cooperate. It's been a good week since i've seen the temp. reading.
Old Apr 16, 2006 | 09:41 AM
Las Vegas
I am bringing it in on Tuesday. I will let you know what they say.
Old Apr 25, 2006 | 06:49 PM
Have you taken your RX in yet? What did they say?
Old Apr 29, 2006 | 01:32 PM
Any update?
They SHOULD be replacing it under warranty...
Old Nov 29, 2013 | 11:10 AM
smtred's Avatar
Heater Controls and Upper dash display OUT!
So last night after an extensive plasti dip job on my rims and hood. I was cleaning my interior while my key was on the ACC position. It fried something and now the Display above where the stock radio is, and the Heater controls are completly out. The fan speed works and thank god its stuck on defrost so im not screwed in the mornings. I know this is a older thread but only one i could find with any infomation on this subject. Has anyone else encountered this and found a fix for it? I will be ripping apart my deck and dash, to try and find something. Would love some input from someone who has solved this problem already if it is possible to DIY it.
TL:DR - Can I Fix my Heater Control unit and upper display w/o replacing it?
Old Jan 12, 2014 | 10:37 PM
billjoebob's Avatar
It's the connecting between your head unit and the radio. Remove radio, check four bolts that hold the radio to the head unit. Then, see if the retainers need to be repaired. I usually repair them with PVC glue and that always fixes then.
nadodave
Aug 28, 2019 05:55 AM
vapor2
Jul 9, 2016 07:35 AM
Turbonostic
Rotary Swaps
10
Sep 19, 2015 11:53 AM
