Big problem with my 8! please help me!
Old Apr 10, 2006 | 08:52 PM
abrahamsaca's Avatar
Angry Big problem with my 8! please help me!
i posted a new thread so that the people dont get confused...
i live in el salvador and the mazda dealer here doesnt bring rx8 so i bought it used in the US and brought it here...
....the problem i have, is that the security indicator its on and the car doesnt start, and we have to put the key in start and then turn off and back again several ti?mes to the car finally starts....we have tried with both keys and it doesnt works..... the next day we have to do the same thing.. the mechanics said that the problem is the ECU...
PLEASE HELP ME!
Old Apr 10, 2006 | 09:26 PM
Tigster's Avatar
RX8 ADDICTED!!!
Are you pushing the clutch in when you turn the key?
Old Apr 10, 2006 | 09:48 PM
yes.. the car is totally block..
Old Apr 10, 2006 | 09:49 PM
the engine doesnt makes sound..
Old Apr 10, 2006 | 10:30 PM
nobody can help me??
Old Apr 10, 2006 | 10:32 PM
alcimedes's Avatar
The burninator
If your'e describing the problem correctly, then it does sound like the ECU. It sounds like the car's security system isn't being activated properly.
Old Apr 10, 2006 | 10:42 PM
..and what can i do??
Old Apr 10, 2006 | 11:08 PM
alcimedes's Avatar
The burninator
Normally I'd say take it to a dealer, but it sounds like you don't have any down there. Not sure what you can do. At this point I think you should contact Mazda North America and ask them what next. Not much anyone here can do for you.
Old Apr 12, 2006 | 09:39 PM
Freddie's Avatar
He didn't say there were no dealers there, just that the dealers there don't sell the RX-8. How similar is our security system to that of other Mazda cars? Does the high-end Mazda 6 have a comparable electronic theft deterrent setup? Somebody has to be able to help him. But I don't know about Mazda North America -- Is there a "Mazda Central America"?
Old Apr 13, 2006 | 12:43 AM
yes they bring mazda 6 and mazda 3, i went to the mazda dealer and they said that the problem is not the ecu, they have to check the car. before the vacations we have in the country.
Old Apr 13, 2006 | 01:13 AM
Winning 8's Avatar
Hot Pit
there is a chip inside your keys, the ignition has a sensor that sense the chip to turn off the anti theft device. since both of your key don't work, it should be your sensor that's having problem.
Old Apr 13, 2006 | 10:00 AM
XRX8X's Avatar
more then a Mazda
QUICK NOTE!most ford dealers have a WDS in house that will reprogram all your keys.
should be under warranty and no charge to you also we here at this dealership have some cars and trucks that somehow forget the code somehow than remembers. we always reprogram the keys (three for the rx8)two masters and one valet key.hope this helps
Old Apr 13, 2006 | 05:49 PM
jaguargod's Avatar
Freedom Costs a Buck o' 5
Is the Mazda North America warranty valid in El Salvador?
Old Apr 13, 2006 | 08:07 PM
DarkBrew's Avatar
Extraordinary Engineering
As stated in the manual, metal key rings can interfer with the operation of the security chips and sensors. Also if two keys are close to each other they will interfer with each other.
Old Apr 13, 2006 | 10:01 PM
Ericok's Avatar
Rotary Wanker
According to the shop manual there are two general types of security system problems:
If the security light is FLASHING, it's giving an error code that corresponds to something being wrong with the Key itself, ignition coil or something is interfering with the key communication to the security system (touching metal, keyring, multiple keys too close together, etc.). You can determine the code by reading the flashes.
If the security light is on STEADY, it's giving an error code for which you need a WDS system to read. The STEADY light means there is a problem of the key communicating with the security module and/or the computer. Almost all the problems associated with the STEADY light can be fixed by reprogramming the key, checking the wiring harness, or replacing the security module. I said ALMOST, the last resort is replacing the computer.
I know this doesn't help you fix your problem but it should give you an idea of what you're up against.
Old Apr 17, 2006 | 11:33 PM
YES THE LIGHT IS FLASHING, AND THE CODE IS 23.
DO YOU HAVE AN IDEA WHAT IT MEANS?
Old Apr 17, 2006 | 11:34 PM
the security light is "steady" like 2 minutes, then start to flash.
Old Nov 15, 2007 | 03:48 AM
shh125's Avatar
so what happened and what was the problem, because mine is flashing too even if i remove the key,
Old Nov 15, 2007 | 04:41 AM
StealthTL's Avatar
It looks like your car has more problems than just the security system, most of those lights should be off.
The bad part is that it WILL start, sometimes after lots of tries, sounds like it's not a loose wire/connector, it's the computer.
Did you disconnect the battery, to reset it? Pull all the computer connectors out and reseat them, check the connectors that run up the steering column, the coil is powered by them.....I'm out of ideas.
If the car behaves itself, except for the security system problem, it can be disabled by Racing Beat - their "race flash" removes the need for the chip recognition - the light still flashes, but the car will start.......only works on '04 manual tranny six-speed model.
LB2739
Jul 9, 2019 02:25 AM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
juicemantwon
Sep 26, 2015 12:30 PM
