Greetings RX8Club member!
Ever think to yourself you don't get enough of us? Well we have the cure for you. The RX8Club.com is on Facebook and Twitter?
Facebook: http://www.facebook.com/RX8Club
Twitter: http://twitter.com/RX8_Club
The Facebook page contains updates from the news and other related posts as well as club member interaction with the admin staff.
The Twitter page provides a random stream of posts to keep you entertained at home or on the go.
Join us today and tell your friends too!
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join RX8Club.com today!
There have been discussions about this before. The other factors missing above are gearing, tire width, and power band.
Set the gearing low, and you increase acceleration while harming gas mileage. Add extra gears in the transmission, and you improve gas mileage, make it easier to stay in the power band for better acceleration, but lose some speed because you shift more often.
Power band is the RPM range for the engine where it is operating at or near peak torque. Ideally you want the power band to be as broad as possible, starting as low as possible.
S2000:
1st 3.133
2nd 2.045
3rd 1.481
4th 1.161
5th 0.971
6th 0.811
Final Drive ratio 4.11
RX-8:
1st 3.760
2nd 2.269
3rd 1.645
4th 1.187
5th 1.000
6th 0.843
Final Drive ratio 4.440
According to this, the RX-8 is geared lower than the S2000, which should be a mark in its favor. The difference, then, has got to be in the power bands. Anyone have a dyno overlay of the two available?
I see that you're getting the hang of the gearing thing no. There are several very important factors that have not been listed in Superchargers comparison though.
One of the biggest factors missing is whether the car is the drivetrain info. AWD makes a big difference in 0-60 times because the wheels don't really spin off the line. Another big factor is if a car is turbo or NA.
HP/wt comparisons between different drivetrain types are less meaningful as are comparisons between FI and NA cars.
Also note that although the RX-8 has higher numerical gear ratios, it has a large wheel/tire circumference. Although it may seem like the rx-8 is geared lower than the s2000, the s2000 is geared for better acceleration since the 1st - 2nd shift comes at a lower speed. The RX-8 was geared for a wide powerband, not for optimal 0-60 times.
Just about all of the other cars in the above comparison probably have 1st - 2nd shift points @ 3x mph and 2nd - 3rd shift points closer to 60mph.
Brian
Thanks for the great explanation, as usual.
Great to see you again Buger. Where have you been and did you get your 8 yet?
I think it's funny that a Subaru Forester was the quickest car in the bunch! :D And it's among the cheapest and heaviest. So much for slow, porky SUV's
Smooth is fast, fast is smooth.
I'm still around occasionally. I've previously posted about using my S-plan.
Several reports have Mazda corporate allowing dealers to accept S-plan in January (at their discretion). A local Mazda dealership reluctantly told me that the gt on s-plan would be around 2700 under msrp.
I have heard that my sport version will be around 1800 under msrp. I gave some of the details of how I got my S-plan in Nov of last year. I wonder how many people did anything with that info?
Mazda RX-8 __ 5.9 s ___ 14.5s @ 96mph __ 247 hp __ 2940 lb __ 0.084
Porsche
Boxster ______6.0 s ___ 14.6s @ 98mph __ 228 hp __ 3024 lb __ 0.075
Both cars have NA engines, RWD and manual transmission.
This comparison suggests that the RX-8 tested by Car&Driver may have less than 247 hp.
Keep in mind that the RX8 has peak torque 161 ft*lbs at 5500 RPM, while the Boxter has peak torque 192 ft*lbs at 4750 RPM. That's more torque over a wider range, and accounts for the difference nicely.
Porsche
Hi Supercharger,
I believe Rich posted something about some Bearded Clam's razor theory that had something to do not assuming too much.
It is true that the hp/weight ratio can be a pretty good metric. Of course you are aware that gearing can alter things a bit. We should all be aware by now that lower gearing (higher ratio) will give you more torque but will lessen the top speed in gear. Mazda designed the gearing ratios of the RX-8 to emphasize the wide powerband rather than quickest acceleration. Because of this the 1st-2nd shift comes around 40mph and the 2nd-3rd shift comes around 70mph. The RX-8 could have been geared for higher torque but I believe that Mazda wanted to avoid the "gas guzzler" tax that would have come if the combined epa figures were 1 or 2 mpg less. Mazda had the exact same dilemna with previous RX-7s.
With the above results, I would think that the Porsche Boxster that you quoted would have the 1st-2nd shift and 2nd-3rd shift come at a lower speed than the RX-8.
Since I know you like searching the internet for stuff , your mission (should you choose to accept it) is to find out the redline speeds in 1st and 2nd gear for the Porsche Boxster that you mentioned. It would also be interesting to find out the redline speeds in 1st and 2nd gear for the Subaru Forester 2.5XT that you quoted.
Even with AWD, that thing must be geared VERY low (high ratios) to get the 0-60 times that you posted. 2nd gear redline probably comes in a bit less than 60 mph for that thing!
Originally posted by Buger Ok, enough post whoring for me. I need to get back to work and I'll never catch up with Zoom44 and Herules anyway.
:o
and Supercharger i have never seen you quote or post any stats incorrectly in th epast but could you double check that forester number please. are you sure it wasn't 5.8 seconds?
No, he got it right. 215 hp and like 240lb/ft. Check car and driver.
While we're heaping praises on it, remember too that it's (as far as I know) the only vehicle thus far to receive a good crash rating on the front offset crash test AND the new side pickup/SUV crash test from
"Since I know you like searching the internet for stuff , your mission (should you choose to accept it) is to find out the redline speeds in 1st and 2nd gear for the Porsche Boxster that you mentioned. It would also be interesting to find out the redline speeds in 1st and 2nd gear for the Subaru Forester 2.5XT that you quoted."
If you choose to look it up, the answers will be a service to the forum as another good example of how gearing can affect acceleration performance.
So the XT gets to 60 in the same amount of time as the Porsche even though it has an extra shift. Then, it leads by .1 second through the quarter despite the brick-like aerodynamics. Impressive for an SUV/wagon/econobox. *grin*
I want that engine and tranny in my RS.
1985 RX-7 GSL-SE in 1986 red - donated to charity @ 255k miles
1998 Subaru Impreza 2.5RS - Green w/stock Rally-gold wheels(The Mythical Unicorn of Imprezas)
