Tech CD info and engine output - DYNO
Old Aug 11, 2003 | 10:58 PM
RodsterinFL's Avatar
I am not a mechanic but I listened to the Tech CD on Engine. It describes the only difference between the standard and high power engine is air intake. Interestingly the intake is automated to open at speeds all around the 6000 rpm mark and where it seems that much of the discussion on this topic has lead to. Do you suppose that there is something to do with the function of these?
Listen to the section on engine and see what you think. Note the RPM points before the ports open and the air charger thing kicks in.
Old Aug 12, 2003 | 12:04 AM
eccles's Avatar
Prodigal Wankler
Re: Tech CD info and engine output - DYNO
Uh, no, it also mentions the third ports in the high-power engine, and the fact that the injectors are different, IIRC.
Old Aug 12, 2003 | 07:54 PM
Right, the number of intakes and the dynamic valve that controls these operating at specific RPM plateaus. I just spoke to my father who is a mechanic and he (his opinion after sharing info on forum) is thinking that either the cars controllers for these features are off in some way (could be due to computer control) or the engine is working as designed irregardless of claimed HP. Wouldn't the dyno output be normal for the auto version without the extra airi ntakes?
Old Aug 12, 2003 | 07:58 PM
except the low power auto transmission setup redlines at 7500 or thereabout. and the peak T would be higher. and you can clearly see the Tertiary ports opening(or partially opening?) on the dyno graphs.
Old Aug 13, 2003 | 12:41 AM
86rx7's Avatar
quick question, what did mazda call the 6th-ports on the tech highlights CD? are they no longer 6th-ports?
vapor2
Nov 3, 2020 03:38 PM
Sifu
Aug 30, 2015 10:51 PM
Tyblat
9
Aug 6, 2015 10:43 AM
dbarber
Jul 25, 2015 01:34 PM
