photoshop help:20" rims, do they fit?
Old Aug 11, 2003 | 12:08 PM
shimm57's Avatar
hey yall im new to this forum but it looks really sweet. Neways i was wonderin if 20" rims would fit on an rx8. I got a pic right here of some that i like.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2426726977
If any of you photoshop experts can put those on a sunlight silver rx8 (preferably with an appearance package) i would greatly appreciate it. No RUSH, take your time.
Old Aug 11, 2003 | 12:54 PM
brothervoodoo's Avatar
RainMan is Back
I'm sure with photoshop you can "make them fit". Will they fit is the question, I don't know. Photoshop is good for giving you an idea of what they may look like when on.
Old Aug 11, 2003 | 05:28 PM
Deep Blue's Avatar
with a Red 8
Here's a crap job, but should give you the idea:
(and by the way, I highly doubt 20" rims will fit on this car...not without some adjustments to the suspension)
I think the 18" are huge enough...most people who see my car saw "it's all rims!"
Old Aug 11, 2003 | 05:47 PM
Deep Blue's Avatar
with a Red 8
Here's another go from the side (again, pretty crap, fast job):
Old Aug 11, 2003 | 06:34 PM
shimm57's Avatar
hey thanks for the help man. Ill think twice before i change my car like that. for some reason i have some weird attraction to chrome.
i must say that i do like the chrome/velocity red contrast but would chrome wheels go with a sunlight silver RX-8??
hmm...
Old Aug 11, 2003 | 08:13 PM
cueball's Avatar
I wouldn't go any bigger than the standard 18s. To fit 20s you would need to roll the fenders and your turning radius would go to hell. Big wheels also add unsprung weight which inhibits acceleration.
Old Aug 11, 2003 | 09:53 PM
QuantumTheory08's Avatar
Redo rim
.....that angle of the rim bothered me so I rotated it 90º.
Old Aug 11, 2003 | 11:36 PM
MrWigggles's Avatar
To answer the question if 20" wheels will fit or not, it depends more on the tires than it does on the wheels.
The stock circumference of the RX-8's OEM tires is 26".
That would mean that technically you need a 245/30 R 20. Only Pirelli Nero makes a tire with those dimensions that I know of. A 30 aspect ratio on a 245 tire is a VERY thin tire and is meant mainly for show. To prevent rim damage, you will probably need to run the tire at a very high PSI and ride quality will suffer.
The next best thing to do is to cheat a little and go with a 245/35 R 20 tire. There are a few companies that make tires of this size including the Bridgestone S-03's which are 26.7 inches in diameter. Your speedometer will read about 3% low because of the difference (i.e. at 70 mph your speedo will display that you are only going 68 mph)
If you really want dubs on your car, then the second option is really the only way to go IMO. Put those tires on a 8.5" 20" wheel like the one shown on Ebay and it should fit. You want to make sure that the offset is at least 40mm for them to fit without problems. The closer the offset is to the factory 50mm the better.
Good luck,
-Mr. Wigggles
Old Aug 12, 2003 | 04:37 PM
shimm57's Avatar
against my will, i got an automatic rx-8 thats comes with the stock 16's. im lookin to upgrade the wheels but i dont know what to do.
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
hufflepuff
May 30, 2016 10:45 AM
Quiggs321
Sep 30, 2015 05:34 PM
GK1707
Sep 27, 2015 07:33 PM
