check engine light
Old Aug 10, 2003 | 05:53 PM
graphicguy's Avatar
check engine light
Got a winning blue RX8 that I've owned for 48 hours. 100 miles on it and the check engine light comes on and stays on. The only thing I've done is wash it. Yes, the gas cap has been put on with 4-5 "clicks". Should I have the dealer "flat bed" it back?
Manual says only to let the dealer know that it's happening. I don't know when I can get back to the dealer.
Thoughts?
Old Aug 10, 2003 | 06:42 PM
brothervoodoo's Avatar
RainMan is Back
Did you check oil level?
Old Aug 11, 2003 | 06:22 AM
graphicguy's Avatar
Checked oil level....it's full. Oil pressure guage is normal....no oil level light comes on.
Old Aug 13, 2003 | 07:50 PM
waiting's Avatar
Just got back from my dealer after having my car checked out because my "check engine light" came on yesterday. Code said it was the thermostat not opening/closing correctly. They checked it out and it looked to be working fine, but they replaced it anyway. I drove it about 90 miles after it was on (the rest of the way to work and back home, and then to the dealer). I did call my service dept. first, and they said as long as the car was running ok (no loss of power, temps normal, etc.) it shouldn't be any problem to drive for a while. I was a little worried they wouldn't have parts in stock yet, but they fixed me right up.
Lightning yellow, MT package
Old Aug 13, 2003 | 08:03 PM
Kurt Bob's Avatar
Question Me Too
I got the check engine light too. I have an appointment next Monday to take it in to the dealer. Since my oil pressure and water temp are fine, I'm not worried. It still runs great.
This is the first car I've ever owned equipped with OBD. Now I know how everyone else feels when the light comes on.
I'll let everyone know what the problem was when they check it out.
Old Aug 19, 2003 | 08:33 PM
Kurt Bob's Avatar
Cool
Well, my check engine light was caused by the thermostat sticking open. The dealer took a few hours to fix it and I'm very happy with the results. I'm glad to get the RX-8 back in place of the Neon loaner!
Old Aug 20, 2003 | 09:34 AM
graphicguy's Avatar
EVAP
They ended up replacing the EVAP unit.
Everything is great, now!
Old Aug 20, 2003 | 12:26 PM
mikeb's Avatar
100% Italian
my check engine came on and I took car in and two days later they told me it was becuase I added subs and neon lights under the passenger and driver side. how does that make sense. The subs ran off battery and neons inside car ran off dome light fuse.
Old Aug 20, 2003 | 12:42 PM
Icemastr's Avatar
Maybe they are setting you up to get out of warranty work because of your subwoofers, hehe. Glad it was a simple fix on the CEL. Just make sure to always try to figure out what it is before driving the car to much more because CEL can mean death!!
Old Aug 20, 2003 | 12:43 PM
graphicguy's Avatar
mikeb
Your servicing dealer is an idiot if they expect you to believe that. Find another dealer to do your service.
Old Aug 20, 2003 | 12:53 PM
seikx8's Avatar
Is this title ok?
Don't you hate it when dealer do that to avoid any warranty claim The only thing that I can think of that cause a malfunction is the sub/neon cause a surge in the electric system, which I hightly doubt Mazda had implement such an advance electric monitor system that trigger the CEL.
The worst a sub or neons can do are blow fuses or short circuit some devices.
On a side note, maybe the safety device such as seat belt or air bag was affected by the wiring, which I'm sure you would not touch those. Then again, it should trigger the SRS light not CEL.
Old Aug 20, 2003 | 01:03 PM
Magnesium's Avatar
Lurking troll
When I got my CEL about 900 miles back they said it was the gas cap...
:P Wasn't me. I think it was the dealer when he filled it up and didn't get it tight. Hasn't returned though. Kinda blows that I had to take it to the dealer just to clear the light.
Old Aug 20, 2003 | 01:04 PM
mikeb's Avatar
100% Italian
well I'm going to pick the car up today. They told me the cel light is off now and if it comes back on they think its due to the subs and lights. BS
Old Aug 20, 2003 | 01:26 PM
RotoRooter's Avatar
There is another CEL thread in the Tech garage section for those interested in posting there. Thanks
Old Aug 28, 2003 | 08:38 PM
leesims's Avatar
My check engine light has also come on twice. I took it to the dealer the first time and they blamed it on overfueling (topping off). This is horsesh!t. A week later its on again. Is this a thermostat problem? What should be my course of action??
Old Aug 28, 2003 | 09:34 PM
CodyNF's Avatar
Actually if you top off new cars, gas will get into a runoff tube in the gas tank and there will be an airpocket so you can't add anymore gas (just like NASCAR cars), it will also throw a CEL. I worked at a dodge dealer and somone brought their car in because they topped it off and weren't suppose to, it threw a CEL. I climbed under the car opened the tube the gas drained it out, reset CEL and I was done. Cost them 1/2 hour for diagnostic, and 1/2 hour for maintenace and it took me 5 minutes to fix, just for topping off their tank.
Old Aug 28, 2003 | 09:36 PM
CodyNF's Avatar
Oh yeah, I also heard their was a bug in the ECU that would throw a thermostat stuck code when it actually wasn't.
Old Aug 29, 2003 | 10:31 PM
RX-GR8's Avatar
Makes sense since the thermostat obviously shouldn't become defective that quickly in a new car but yet I've heard people say the dealer replaced the thermostat instead of checking the ECU.
Old Aug 30, 2003 | 12:49 PM
waiting's Avatar
I got my car back from my dealer last week after it's second trip in for CEL coming on. First time they said it was a thermostat code, replaced it, even though they said the thermostat seemed to be working fine. The second time I had it in they called Mazda. Mazda said they've had 12 or 15 cars with the same trouble; CEL comes on, shows thermostat code, but thermostat is fine. Seems there is a problem in the car's computer that they're working on. My service manager called me a few days ago asking specific questions about my driving habits, conditions, etc, so he could report back to Mazda. He said that if it came on again not to worry about it (as long as pressures are OK), and that Mazda expected to have an update disk sent to dealers shortly that would correct the problem after bringing the car in and downloading the new info into the car's computer. A bit of a hassle with the trips to the dealer, but they've been great at getting me in--both times they told me to bring in right in and had me in and out in a few hours the same day I called.
Old Aug 30, 2003 | 12:53 PM
IwantONE2's Avatar
My car finally arrived at the dealer. I can't pick it up until Tuesday because the don't have anyone in to do the prep work this weekend.
The salesman let me sit in it and pull the car into the garage. As soon as I started the car the CEL came on. Could this be just from them not doing the pdi yet, or should I be warry of buying the car.
He let me pull it into their service garage and it should stay there until the mechanics arrive Tuesday morning.
I've been waiting for 2 months. My first car was wrecked in a train derailment. Now this. I sure hope its nothing serious.
Old Aug 30, 2003 | 01:47 PM
r0tor's Avatar
... just a question...
how many check engine lights do we have?
My Probe has a yellow check engine light which is related to emissions systems and a red check engine light meaning your screwed. Do RX8s have the same thing?
Old Aug 31, 2003 | 06:33 PM
BlueAdept's Avatar
Moderator
Does anyone have any information regarding how to interogate the cause of/reset the CEL...
In the Imported Lexus SC400 which I nearly bought 2 years ago you could short 2 pins on the diag socket and it would display the code on the digital display...
Old Aug 31, 2003 | 06:57 PM
Boccelli's Avatar
Of the 3 times I test drove the vehicle, the check engine light came on all 3.
Old Aug 31, 2003 | 10:10 PM
graphicguy's Avatar
CEL
Mine was the EVAP unit....part of emmisssions control computer. They replaced it, no trouble since.
Old Sep 1, 2003 | 04:01 AM
Superbone's Avatar
I just took mine into the dealer on Friday because the CEL came on Friday morning and stayed on. Got a call and they said it was due to the gas cap not being seated correctly. I had read that in the manual and of course checked it and it seemed to be fine. Anyway, they told me that it doesn't sense it very often so it takes a while to go off.
But, I told them that I had issues with flashing oil check light and had to put 1/2 gal of oil into it. So, they're ordering me a new type oil pan and will be downloading new software into the computer.
