Fuel Injection services
Old Mar 18, 2006 | 01:18 PM
RX-Aight's Avatar
shaaaaaa...
Can the RX-8 take normal fuel injection chemicals Like these:
http://www.mightyautoparts.com/produ...#intakecleaner
I've got my own fuel injuection cleaning kit where I hook up to a vacuum line usually off of the brake booster, etc. Use them regularly on my other vehicles (QX4 and a Jeep Wrangler) but just wanted to "double check" before using on my RX-8.
BTW, I got a 4,000 mile service card in the mail the other day "fuel induction service for $189.00" Seems pretty high since the chemicals usually only cost around $10.00
Old Mar 28, 2006 | 02:41 PM
rotarygod's Avatar
I've never had any issues using fuel injector cleaners on rotaries so I don't see what the problem would be with th RX-8.
What do you mean you hook up to a vacuum line off of the brake booster?
Old Mar 31, 2006 | 02:38 PM
dgrx8's Avatar
FN GR8
15,000 mile service
i just got my car serviced at 12k miles & was told that the next service included cleaning the fuel injection system. have any of u done this through your dealer? is it worth it or should i do this myself??
Old May 24, 2006 | 02:24 PM
Rotobaby's Avatar
I just had my car serviced, 35K miles. Actually had it towed in cuz it wouldnt start (1st time ever). Anyway, they replaced the starter, plugs, battery plug wires all under warrenty. I paid for the induction sys cleaning ~200$ . Well lets say I was very happy and im getting 2 mpg better (16mpg whoohooo). Maybe it was the plugs maybe the fuel system cleaning?? But the car has more power (butt dyno) and 2 mpg's better. Im not sure how they did the cleaning but I got a PO302 code when I drove away. Went back, cleared it, not seen again.
Old May 24, 2006 | 04:37 PM
snkpkp's Avatar
so we can use regular injector cleaners in our 8's? like adding them with the fuel?
Old Jan 7, 2009 | 06:13 PM
RX-Aight's Avatar
shaaaaaa...
I was talking about hooking it up to the vacuum i.e. brake booster. I did it a few times and cleaned the throttle plate with cleaner and rags. seemed to work good... can't tell if it ever helped mpg
Old Jan 7, 2009 | 07:03 PM
04RX8man's Avatar
Rotary Powered Countryboy
all of those are good From what i hear Seafoam seems to b one of the best!
Hunterkelley24
Jun 14, 2022 08:32 AM
JCTaylor
Sep 30, 2015 07:31 PM
RotaryMachineRx
Sep 29, 2015 10:26 PM
DeltaJ802
Sep 29, 2015 01:20 PM
Jb4ker96
Sep 27, 2015 10:06 PM
