Car weight check your door panel
Old Aug 8, 2003 | 12:21 PM
Wing's Avatar
Interesting....... Unless I read it incorrectly I didn't have my glasses on.
The manual states the canadian spec RX8 is 3050lbs I believe the US is 3028. Anywho.....
Open your driver door and check the weight listed there. Mine says something like 3500!!
I'm going to double check it.
Old Aug 8, 2003 | 12:30 PM
KyngNothing's Avatar
Is that gross (max) vehicle weight?
Old Aug 8, 2003 | 12:46 PM
Spin9k's Avatar
Momentum Keeps Me Going
The GVWR is the maximum allowable weight of the vehicle, including occupants, cargo, fluids and fuel. Also: Gasoline: 6.0 pounds per gallon.
Curb Weight 3029 5-sp 3053 auto, source: USA RX-8 manual
Old Aug 8, 2003 | 12:47 PM
RomanoM's Avatar
I Just Can't STOP!
That is NOT curb weight!
It's GVWR - gross vehiclw weight rating
GVWR is the max weight, the car itself, passengers and luggage can not excede the GVWR
Curb weight is the weight of an empty car with a tank full of gas and all fluids topped off.
Old Aug 8, 2003 | 01:03 PM
jonalan's Avatar
Pu-36 Space Modulator
Wait, so this means we can only add less than 400 lbs in passengers/cargo? That's not very much!
Old Aug 8, 2003 | 01:04 PM
IwantONE2's Avatar
Excuse my extreme ignorance on this stuff, but if the car weighs roughly 3,000 pounds without occupants and the max weight is 3,500 pounds, how is it safe to have four adults in this car?
They'd have to be four women. Or myself and three naked supermodels. I guess that would be ok.
Old Aug 8, 2003 | 01:07 PM
RomanoM's Avatar
I Just Can't STOP!
GVWR is actually about 3850 lbs. Or about 800 lbs. of "stuff"
Old Aug 8, 2003 | 01:11 PM
Spin9k's Avatar
GVWR = 3809 lbs 5-sp 3854 lbs auto, source: USA RX-8 manual
or 780lbs for 5-sp, 801 lbs auto for everything but EXCEPT what is included here:
Curb Weight: The weight of an empty vehicle (without passengers or payload), but including oil, gas, coolant, and other standard equipment.
Old Aug 8, 2003 | 01:35 PM
eccles's Avatar
Prodigal Wankler
It's hard to explain, but try to imagine all life as you know it stopping instantaneously and finding yourself confined forever in another dimension.
Oops, no, that's if you cross the beams. Probably perfectly safe then. Try it, and let us know when you return from that other dimension.
Old Aug 8, 2003 | 01:38 PM
Tweety-nator's Avatar
Still, 800 lbs is quite low.
I think the average American male weighs about 200 lbs ... thats about 4 people right there ... which leaves nothing left for the stuff in the trunk.
I am just curious, maybe this is normal for cars of this size ... I dont know.
EDIT: I checked online and found that the actual average American male weight is 179 lbs, which totals to about 716 for 4 people. That leaves about 84 lbs left to haul stuff. Not much...
Arg, now I find out that I am overweight based on that average... time to reduce my junk food intake!
Old Aug 8, 2003 | 02:01 PM
MrWigggles's Avatar
It gets worse.
The GVWR does not include gas either. A full tank is about 100 lbs.
EDIT: Curb weight does have fuel factored in.
Mazda advertises the car is designed for "4 6-footers". The healty weight limit for a 6 foot male is 190 lbs. (yes, over about 190 and a 6 foot male is technically considered "overweight")
So 4 X 190lb + 100lb = 860lbs (Edit: make that 760lb)
So with 4 non-overweight 6 foot males, a full tank of gas, and NO luggage you have already exceeded (edit: close to exceeding) the maximum safe weight rating (GVWR) for the car.
Have a nice day,
-Mr. Wigggles
Ps. A lot of cars have this problem. In the US this GVWR issue is typically ignored unless you are doing something ridiculus, but in Canada I think they take it a little more seriously. http://www.pc.gov.bc.ca/cmg/newweb/GVW.htm
Old Aug 8, 2003 | 02:23 PM
TreknMazda's Avatar
Love it! Keepin' it!
The US may start taking GVW more serious, especially the FAA. Out of date standards for body weight was considered as a possible contributor to the miscalculation of the take-off weight and balance of a commuter plane crash a few months back.
Old Aug 8, 2003 | 02:26 PM
wakeech's Avatar
mostly harmless
dude, the (rather rediculous) American BMI puts me at almost 40 lbs overweight for my height (i'm 190cm, 6'2.6", i weigh about 220lbs), and trust me, < 25 lbs of that is fat (less than 10%bf).
Old Aug 8, 2003 | 02:31 PM
Spin9k's Avatar
Originally posted by MrWigggles
It gets worse.
-Mr. Wigggles
Think you better check again Mr Wigggles, GVWR includes fuel and more. See previous post above.
Old Aug 8, 2003 | 02:39 PM
mikeb's Avatar
100% Italian
Who has 3 supermodels in their 8! j/k
Old Aug 8, 2003 | 03:58 PM
You seem to be a very fit/healthy person ... however bear in mind that because you weigh in at 220 lbs that means 4 of you will definitely exceed the RX-8's GVWR!
Make sure any friends you bring along for a ride are malnourished to compensate :D
Old Aug 8, 2003 | 04:18 PM
MrWigggles's Avatar
Yes you are correct. fuel is included in the curb weight.
So, I guess Mazda was correct. The car can hold eight 6 foot males as long as none of them are overweight and there is no luggage.
-Mr. Wigggles
Old Aug 8, 2003 | 05:45 PM
Jasper_the_2nd's Avatar
Damn, I definately exceeded GVWR at lunch then.
4 IT people, and you know how slimming sitting in front of a computer 8+ hours a day can be
If we didn't exceed it leaving work, I'm betting we did by the time we left the Chinese restaurant :D
rotarywanker
Dec 8, 2022 05:56 PM
blkswan
West RX-8 Forum
Oct 24, 2016 11:34 AM
akagc
Aug 11, 2015 07:07 PM
Majictoast
Jul 18, 2015 06:45 PM
AussieGray
Jul 16, 2015 03:58 AM
