Illuminated Shifter Knob
Old Aug 7, 2003 | 09:02 PM
Goldenhue22's Avatar
Illuminated Shifter ****
Does anyone know if the installation of the illuminated shifter **** will be a problem in the US spec 8's. Is it easy to install?
Old Aug 7, 2003 | 11:54 PM
ramfann's Avatar
where did you find it? i will order one and tell you how it goes
Old Aug 8, 2003 | 01:59 AM
Titanium Grey's Avatar
RX-8 wher art thou RX-8
They're a standard accessory in the UK so it's one of the must haves for me.
There will have to be some sort of wiring in the gear leaver, take your gear **** off and have a look, there may just be one wire though because it may 'ground' through the metal of the gear leaver itself.
Old Aug 8, 2003 | 09:11 AM
eccles's Avatar
Prodigal Wankler
Having had the gear shift boot and surround off as part of the MP3 player install, I can tell you that there's no dedicated wiring for the shift **** under there. I suspect the illuminated **** will probably draw its power via a wire tap spliced into the ashtray lighting.
Old Aug 8, 2003 | 03:16 PM
tripwire's Avatar
W!ck3d $!ck
I thought I read somewhere that the "Red" glow is always on, created from an "Indiglo" effect. Like on "Indiglo" writs watches. As though it had a button cell battery in it. Could be wrong. I'll try to find where I read that.
Old Aug 8, 2003 | 10:42 PM
RAMFANN- Go to JAPANPARTS.COM
They have everything there. They told me that the illuminated **** will work on US spec cars. I just wanted to know if someone has done this yet as they may just a sale.
Old Aug 8, 2003 | 11:22 PM
tripwire's Avatar
W!ck3d $!ck
I didn't see it listed in their inventory - did you find it on their website?
Old Aug 8, 2003 | 11:28 PM
The Beav's Avatar
Wankel-meister
i'm pretty interesting in seeing how's it illuminated, i don't think i could deal with a wire, but if it's battery powered that'd be cool, or maybe even solar powered, like those glow in teh dark watch hands
Old Aug 9, 2003 | 12:16 AM
eccles's Avatar
Prodigal Wankler
You wouldn't even know the wire was there if it was thin enough to pass between the shift shaft and the shift boot; the wiring would all be hidden under the boot.
Old Aug 9, 2003 | 02:36 AM
ramfann's Avatar
are you talking about the leather shift **** that has the shift pattern light up?
Old Aug 9, 2003 | 05:51 AM
Jt-Imports's Avatar
Bro you need to have the wiring. Its kind of a bummer. Some RX7 guys wanted it a while back so I looked into it, and there is a lumination light for the Jspec ones at least.
JT
Old Aug 9, 2003 | 08:16 AM
Puppy1's Avatar
Pure Unadulterated Fun
Exactly.
theblinkof
Oct 4, 2023 05:24 PM
200.mph
Dec 10, 2018 03:49 PM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
RX8mzda
Oct 1, 2015 10:17 PM
Vedivan1
Sep 20, 2015 04:39 PM
