How many intend to autocross their RX8?
Old Aug 7, 2003 | 02:43 PM
PUR NRG's Avatar
I count eccles, rotarydude and myself as the only ones I know about. A show of hands please?
Since the car is so new I figure we should pool all the info we learn in order to (forgive the pun) get up to speed as quickly as possible.
________
EXPERT INSURANCE
Old Aug 7, 2003 | 02:57 PM
eccles's Avatar
Prodigal Wankler
tpryor will be 'crossing his, too.
Old Aug 7, 2003 | 04:31 PM
tpryor's Avatar
Absolutely! I have to complete the break-in, decide what alignment to start with, does it need a bar, does it need shocks, does it need............?
My head hurts with all the decisions (and, my wallet). I hope to get a LOT of feedback from the other members.
Old Aug 7, 2003 | 05:08 PM
Lethalchem's Avatar
If I end up buying one, it will be autocrossed.
Old Aug 7, 2003 | 05:10 PM
sburkett's Avatar
I will be autocrossing mine a little, first event for it is Sunday. I probably won't spring for race tires, at least not this year. I used to solo a 3rd gen RX-7 in ASP pretty seriously, but am more focused on road racing (EP 1st gen RX-7) lately.
The only "mod" I'm going to do is add a little negative camber in front. It will definitely need shocks, but I'd wait till next season on that, there aren't enough options available yet.
Steven
Old Aug 7, 2003 | 05:25 PM
tpryor's Avatar
Originally posted by sburkett
It will definitely need shocks, but I'd wait till next season on that, there aren't enough options available yet. Steven
Penske has fully adjustable, customer rebuildable shocks that fit the RX-8 today. If needed, I would just want to come up with the initial damping specs.
Old Aug 7, 2003 | 05:46 PM
Randy's Avatar
I've tried it, but unless the S2000 goes to A-Stock, I'm racing the S2000 instead.
Old Aug 7, 2003 | 06:41 PM
TybeeRX-8's Avatar
I REALLY LOVE THIS CAR!
I'll be running in the Buccaneer Region...as soon as the damn thing gets here!
Old Aug 7, 2003 | 06:43 PM
PUR NRG's Avatar
Do you know which model and size shocks that would fit? I emailed Aaron Lambert @ Penske about this and while he recommended the 8760 triple adjustable shock (most expensive of course) he had no idea about fitment.
Are coil overs legal for BSP? The rulebook says springs must use original attachment points which would imply no, but I wanted to make sure. And if coil overs are okay for BSP, are the Penske shocks offered as coil over units?
________
Avandia Lawsuit
Old Aug 7, 2003 | 11:45 PM
eccles's Avatar
Prodigal Wankler
Rule 14.8.A also says "Coil spring perches originally attached to struts or shock absorber bodies may be changed or altered, and their position may be adjustable." I'm no expert, but it sounds to me like you're good to go.
Old Aug 8, 2003 | 08:23 AM
markh711's Avatar
Already autocrossed.
Old Aug 13, 2003 | 10:20 PM
Sparky's Avatar
I talk to cones
First Event this Sunday in Nashville. I'm planning to spend Saturday with a pyrometer and camber gage so I should have some rough settings for street tires early next week. I'm going to start 1.8 front/1.5 rear with 1/8" toe in the rear and go from there.
With the factory alignment it pushes under power and tucks in dramatically off the gas. I'm going to try to smooth that out with more front camber and rear toe.
From what I've read, the eight has similar, but improved, suspension geometry to the FD RX-7. so I'm using that as a starting point.
05TR1CH
Apr 18, 2023 04:56 AM
SUKIEE
Oct 9, 2017 09:41 PM
SupraG
Sep 21, 2015 12:09 AM
vetteor8
Jul 25, 2015 11:43 AM
RX7.9
Jul 20, 2015 12:01 PM
