Purpose of the 4 rubber gromets
Old Feb 25, 2006 | 09:36 PM
mcrx8's Avatar
I just purchased my 2005 rx8 and noticed it had these 4 rubber gromets that appear to attach to the frame rail underneath the car, mine are not attached,(found in glovebox) my car has the factory mazda areo kit installed. Is this why they weren't installed, or do I need to install them? Also what is the purpose of these rubber gromets, found no mention of them in the owners manual.
Old Feb 25, 2006 | 10:57 PM
TrackAddict's Avatar
I miss my 'Bu
Used as an anchor point to tie the car down when loaded onto a flat bed. Grommets simply close up the hole when not in use.
Old Feb 26, 2006 | 05:29 AM
Go48's Avatar
Go here:
http://www.finishlineperformance.com...01-05-1472.pdf
Old Feb 26, 2006 | 08:40 AM
mcrx8's Avatar
Thanks for the replies guys, so it sounds like the I need to re-install these tie down rubber gromets, is that correct? Why only the two rear gromets on models after April 2005. Can this cause a corrosion problem if not re-inserted?
Old Feb 26, 2006 | 09:57 AM
Go48's Avatar
Yeah, the dealer should have done installed those before delivering the car. Only two because only two holes after that point.
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
dmengel
Feb 16, 2016 09:47 PM
uZu
Dec 30, 2015 12:35 PM
gwilliams6
General Automotive
60
Nov 3, 2015 02:50 PM
Rotary Swaps
Sep 21, 2015 04:52 PM
