ECU clear/reset - what are the numbers 01, 02, 03, "on" and "off" display?
Old Feb 23, 2006 | 10:16 AM
delrmx01's Avatar
I was messing around the car last night and found it. When you clear or reset the ECU via the odo, you're able to scroll to a number of functions? I don't even know what to call it-- can someone shed some light on this?
What does the 01, 02, 03 stand for? It went all the way up to 50 I think, some of them even had "off" and "on" displayed.
Thanks for clarifying--oh and if there's a thread on this--can you please post it? I don't really have a clue on what to search for.
Thanks again !
Old Feb 23, 2006 | 11:00 AM
delrmx01's Avatar
Anyone?
Old Feb 23, 2006 | 11:02 AM
its teh test mode for the instrument cluster. you can cycle thru each instrument and check its operation. there are posts and at least one thread. search like- dash test
Old Feb 23, 2006 | 11:48 AM
delrmx01's Avatar
Thanks, I just tried it and couldn't find anything. Are they specifically for instrument only? I'd like to know what each number represents, like how the codes represent when you get a CEL?
Would this information be in a shop manual? I was scrolling though them and I saw "on" and "off" just curious as to what they represent.
Thanks again !
Old Feb 23, 2006 | 02:34 PM
Go48's Avatar
Thanks again !
Is this what you're looking for? There are additional pages--too many pages to post here--in the shop manual describing the ON/OFF readouts for each code and what they mean.
Attached Thumbnails ECU clear/reset - what are the numbers 01, 02, 03, "on" and "off" display?-checkcodes1.jpg   ECU clear/reset - what are the numbers 01, 02, 03, "on" and "off" display?-checkcodes2.jpg
Old Feb 23, 2006 | 02:57 PM
delrmx01's Avatar
^^Yes !! That's it --thanks Go48. I guess, the codes are sort off like a check list of the instrument panel?
Old Feb 23, 2006 | 03:25 PM
Go48's Avatar
Here's an example of check code 04 details. I believe that these codes are normally read using the WDS for diagnosing problems.
Attached Thumbnails ECU clear/reset - what are the numbers 01, 02, 03, "on" and "off" display?-checkcodes3.jpg
Old Feb 23, 2006 | 04:51 PM
delrmx01's Avatar
Thanks again Go !!
Old Feb 23, 2006 | 04:56 PM
Go48's Avatar
Sure.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
dezau
RX-8 Racing
10
Mar 9, 2016 09:50 AM
ShellDude
Oct 1, 2015 09:55 PM
archon
Oct 1, 2015 06:08 AM
