proper launch
Old Feb 14, 2006 | 07:40 PM
Rena my Rx8's Avatar
Unhappy proper launch
hey guys, ive been struggling in executing a good launch in my 8... can ne one walk me through the correct process, ive been getting frustrated lately, thanks for the help....
Old Feb 14, 2006 | 07:51 PM
expo1's Avatar
He's as bad as Can
https://www.rx8club.com/rx-8-racing-25/best-launch-rpms-60308/
https://www.rx8club.com/australia-new-zealand-forum-37/rx8-hard-launch-36862/
https://www.rx8club.com/rx-8-discussion-3/rpm-best-launch-32412/
https://www.rx8club.com/series-i-tech-garage-22/what-rpm-do-you-launch-21431/
https://www.rx8club.com/rx-8-discussion-3/how-launch-8-a-668/
Old Feb 14, 2006 | 08:07 PM
BlueRenesis82's Avatar
Registered Tracker
god help you
Old Feb 14, 2006 | 08:35 PM
yiksing's Avatar
the giant tastetickles
Practice makes perfect. High rpm NA requires different skill to launch than Low rpm torque machines (V8 or FI)
Old Feb 14, 2006 | 09:39 PM
thanks expo 1 i read all the threads, but there are still several different views on it, guess i have to try it myslef, but thanks for the info guys!!
Old Feb 15, 2006 | 12:09 AM
Ike's Avatar
Ike
Blue By You
Drop the clutch at 7k+ and pray for no wheel hop!
Old Feb 15, 2006 | 01:08 AM
lazi's Avatar
drivelinestore.com
drop clutch from 9k its koo. u'll win no mater what. =P
Old Feb 15, 2006 | 01:52 AM
DARKMAZ8's Avatar
"Call me Darkman"
Start in 6th
Old Feb 15, 2006 | 03:31 AM
maybeashinka?'s Avatar
Can I change my username?
i make tight u turns by letting the clutch out slowly at like 7k in 1st then let off and drive normally..i just hate the whole backing up in the middle of the road thing..sorry to thread jack ur *** :P
Old Feb 15, 2006 | 08:27 PM
The Mighty Red's Avatar
Rally Car Racer
DragToys put it best. The only thing I could add is - if you have DSC, hold the button in for 7 seonds to completely disable it.
1. Jump out of the car and drop tyre pressure to 20psi.
2. Smoke those tyres up good to get them warm.
3. Rev to 7g
4. Slip clutch out and launch.
5. Keep gas on when changing gears that is why you have a rev limiter :D
6. Run a 14sec pass. :D
Note that number 4 above takes practice. You don't pop the clutch out in an instant but rather smoothly but quickly slip it out. Quickly....
A solid suspension setup will help reduce wheel hop. Sticky tires will give you more grip off the line.
If you really want to drag with the 8, swap the engine for V8.
http://videos.streetfire.net/categor...CDEE751CE2.htm
Old Feb 15, 2006 | 08:32 PM
Im_DANomite's Avatar
I love GOOOLD
how long will your axles, differential, etc. last??
Old Feb 15, 2006 | 08:38 PM
Rally Car Racer
Mostly the clutch and tranny you need to worry about.
The clutch burns out from doing this and you always run the risk of blowing your gearbox. Just ask forum memer Judge Ito - he's gone through at least two gearboxes.
drlubell
Sep 26, 2015 11:58 PM
Ian_D
Rotary Swaps
Sep 23, 2015 11:22 AM
teamdipngo
Sep 14, 2015 02:47 PM
Jonesboy2398
Sep 13, 2015 05:28 PM
