What would 225/40ZR18 to the drivability if the 8?
Old Jan 30, 2006 | 04:57 PM
subduedracer's Avatar
Realtor1
Question What would 225/40ZR18 to the drivability if the 8?
I have a set of tires I'm looking at that are a decent deal. Not sure if I will like the size. (in referance to hieght) Opions tire techS?
Old Jan 30, 2006 | 05:02 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Originally Posted by subduedracer
I have a set of tires I'm looking at that are a decent deal. Not sure if I will kike the size. Opions tire techS?
Is that a politically correct post? You have something against a certain religion?
As for the tires. Your speedo will be wrong a bit, but otherwise the diffs should be minimal. Why dont you just get the right size?
EDIT:Oh, and if you get 225/45-18 or 225/40-18 you better have 18 inch rims. If you have 17, your tires might fall off! https://www.rx8club.com/lounge-4/my-friends-tire-just-came-right-off-81686/
Old Jan 30, 2006 | 05:04 PM
sstricker's Avatar
of course i searched!?
HAHAHAHAHAHAHAHAHA... i was wondering the same thing!!!
guess he could always smoke a bowl....
Old Jan 30, 2006 | 05:10 PM
expo1's Avatar
He's as bad as Can
From http://www.miata.net/garage/tirecalc.html The speedo would be 3.4% too fast, 60 mph would really be 58.
My track tires are 235/40/18 and run great, can you get that deal on that size? Speedo diff on that size is 2.2% too fast.
Old Jan 30, 2006 | 05:12 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
That is great, so you would get a torque boost to boot.
Old Jan 30, 2006 | 05:15 PM
Realtor1
Great info expo1.
Old Jan 30, 2006 | 07:20 PM
musclecarconvrt's Avatar
Before you buy, check out the Kumho 245/40 18's on www.TireRack.com. Hard to beat the price. I think I paid around 135 per tire a year ago. All the other comperable tires were in the 180 range. It's a good tire too. I didn't even make it a full year on the stock tires. They were bald in 11 months! These Kumho's handle better that stock and are lasting longer to boot. Fits perfect.
Old Jan 31, 2006 | 06:22 PM
GeorgeH's Avatar
Beware of bent wheels. I've bent several of the OEM wheels on the 225/45 profile - reducing the sidewall by 10% is just going to make things worse.
Also, make sure the load rating is sufficient for the RX-8.
Old Feb 2, 2006 | 09:34 AM
Realtor1
I went with 245/40 ZR18 Yoko's. ES100
Looks great so far
Old Feb 2, 2006 | 09:40 AM
Cool, Please let us know how you like 'em. put a lot of miles on my car and may need a new set of tires by summer or fall.
Old Feb 6, 2006 | 03:02 PM
Philip_SA's Avatar
Rotary lover
Hi all
I have the same problem of having to fit new tires.I also thought off fitting 225/40-18 as they are exactly 3 times cheaper, than the 225/45-18.(here by us in SA) in Rand a 225/45-18 is about R2700 to R3300 per tire, the /40's are between R900 and R1100 per tire.
Can you believe it,they say that /45 is not a common size ?
This now will also let me go for 225 or 235/40.
Thanks guys
I want to buy lowering springs and are looking at: TeinStech, H& R, Racing Beat, and Eibach on Rx7store.net.
the TeinStech price is good does anyone have a problem with them
uZu
Dec 30, 2015 12:35 PM
SupraG
Sep 21, 2015 12:09 AM
MadDog
9
Sep 13, 2005 08:03 PM
RX8_Buckeye
Dec 24, 2004 03:09 PM
Supercharger
General Automotive
22
Nov 30, 2003 07:15 PM
