An idea for passing emissions with a turbo
Old Jan 30, 2006 | 12:28 AM
mike1324a's Avatar
Need'd a Turbo
I was trying to think of a way to pass emissions with a turbo. Would it be possible to have a custom midpipe with 2 (maybe more) high-flow cats on it and pass emissions with the turbo installed? Just an idea. Install this pipe when ever you want to get tested for emissions and then take it off afterwards. Would this put too much back pressure or anything on the system to be a danger? What do you guys think? Is this possible, could it work?
Old Jan 30, 2006 | 10:53 AM
Red Devil's Avatar
This is why most, if not all, factory turbo systems have downpipes with catalysts. At least all the turbo RX-7's had this. It's there to heat-up the exhaust gas because heat is what causes the needed chemical reaction in the catalyst. It's not the number of cats, it's the heat that is needed at start-up that's the problem.
Along those lines, I always thought maybe having some sort of bypass valve to go around the turbo and straight to the converter at warm-up may address this issue. Then again, I may be missing a very important technicality.
Old Jan 30, 2006 | 10:55 AM
rotarygod's Avatar
If you have a cat installed already, I'd just go get it tested to see what happens.
Old Jan 30, 2006 | 11:12 AM
rkostolni's Avatar
The problem with MD, VA, and a few other states, is that they don't actually sniff your car's exhaust. They just plug into the OBDII port and look for any codes. No codes, you pass. I think that's much more difficult to get around.
The Greddy turbo was submitted for CARB approval already by Greddy. It will take a few years, but Greddy must believe the car will still pass emissions.
Old Jan 30, 2006 | 11:30 AM
MazdaManiac's Avatar
Why not just have your car in a good state of tune so that it has no codes? That is what I've done.
Old Jan 30, 2006 | 12:49 PM
rkostolni's Avatar
How does your ecu not throw a code when you have AFR richer than the stock ecu wants to see? Most people, if not everybody, using the Interceptor has CEL's for system too rich. The only reason the emanage users don't is due to the cold temp dongle.
Old Jan 30, 2006 | 02:41 PM
mike1324a's Avatar
Need'd a Turbo
In terms of sniffing the exhaust, all that is needed is good, thurough warm up before hand and passing in turbo form is possible? In georgia i believe they use the direct computer hook up as opposed to the actual exhaust pipe. Is there any way to pass that, or any loop holes?
Old Jan 30, 2006 | 02:56 PM
cgrx's Avatar
DRIVEN
change cars
Old Jan 30, 2006 | 06:12 PM
Well, the dongle isn't why the E-Manage doesn't throw a CEL, but you can do a similar trick for the Interceptor that spoofs the front O2 sensor.
Old Jan 30, 2006 | 06:57 PM
rkostolni's Avatar
If you have some free time later some more details for that mod would be greatly appreciated!
Old Jan 30, 2006 | 07:03 PM
You would need to construct a dongle like the one that Greddy now includes to defeat the CEL that results from the air pump issue. It is just an SRC with a resistor.
Then, you would hook it up to turn on when under boost.
You would have to fool with resistance values so that it reads approximately 13:1 or so.
A high-power, multi-turn pot would probably be best and you could monitor the resulting value with a CAN scanner.
Old Jan 30, 2006 | 07:24 PM
how soon does the CEL come on? if you have a can scanner just clear the CEL.
Old Jan 31, 2006 | 09:36 AM
FLybOi drE's Avatar
i've read they're very sporadic...theres no way to know how long it will stay on or off...i have a b&b testpipe and had a CEL for a while, and now its been gone for 2months now...weird but im not complaining
Old Jan 31, 2006 | 11:41 AM
adrian-1's Avatar
Ex- member.
With my interceptor, the CEL reappears after a few minutes of clearing it. Due to the idle being rich.
Old Jan 31, 2006 | 01:04 PM
rkostolni's Avatar
Same here. Even without going into boost it will show up after 3 or so drive cycles.
I wonder if there be any problem with fooling the O2 all the time, as far as affecting anything like DSC, or ABS?
Old Jan 31, 2006 | 08:19 PM
drifter_d's Avatar
Registered Drifter
Man, I've been trying to either get transfered or find another job in AZ for a long time, so it ain't for a lack of tryin'! Have family living in Tucson, but I'd love to settle in Phoenix, which is where you're at, if I remember correctly. Maybe I'll send YOU my resume... lol. Warm wishes from cold and windy MD.
Old Jan 31, 2006 | 10:51 PM
You will fail emissions if the PCM has been cleared too recently.
The emissions computer can tell if the car has had enough drive cycles to establish the CAT efficiency and idle standards table.
Old Jan 31, 2006 | 11:10 PM
well there ya go.
Old Jan 31, 2006 | 11:14 PM
Well, that is not quite what I meant by "state of tune", but that is clever.
Actually, I don't know what the emissions standard is here in AZ. I suspect it might be strict because of its poximity to Cali.
I'm not going to register here until I have to since the taxes are high on new-ish cars. Probably two years when the emissions test in MD is about to expire.
Old Feb 1, 2006 | 06:14 PM
BigOLundh's Avatar
#1 Legend
I am sure if you constructed this you could sell a ton in a heart-beat. Essentially every person who owns the interceptor-x would probably want one.
Old Feb 2, 2006 | 02:10 AM
GTR's Avatar
GTR
need BOOOST!!
In California, The BAR97 machines just makes sure that your OBDII monitors has ran and that they're no DTC's set. By California smog rules, you are allowed only two monitors incomplete.
Old Feb 3, 2006 | 12:54 PM
Umbra's Avatar
So your saying if the car has been in storage without a connected battery it's going to fail emisions if it isn't driven a while before hand?
Old Feb 3, 2006 | 01:04 PM
Probably. I don't know how long the NVRAM cap will last without being grounded.
If, when you go to start the car, the DSC and power steering lights are on, your drive cycle info is gone.
Old Feb 3, 2006 | 07:45 PM
I have't been following the Interceptor stuff, but is there some reason you can't make a leaner "emissions purpose only" program; slap it in there, putter around to get the necessary drive cycles, get your test, and then back to your normal program?
Old Feb 3, 2006 | 08:36 PM
GTR's Avatar
GTR
need BOOOST!!
That is exactly whats going to happen if none of the OBDII monitors are not complete. Try it. Any CAR 1996 & newer. Disconnect the battery and you will fail the smog inspection in California. A lot of people still think they can disconnect their battery to clear that check engine light before they go to the smog station. I catch so many people lying that way.
