need help!
Old Jan 18, 2006 | 12:18 AM
thaiboyrx8's Avatar
need help!
my name is Andy. firstly I've to let you know my english is not good.you might don't understand what I say.
so my problem is about break noise.
I went to dealer and let them checked the brake and they said nothing can do much with these problem.If they change me the new parts and then the noise will happen again so I don't know what to do .
anyone can help me?
I bought the car from Prima Mazda.
help me Please!!!!
Please!
Thank you very much.
Old Jan 18, 2006 | 03:40 AM
yiksing's Avatar
the giant tastetickles
Metallic brake pads squel, its normal
Old Jan 18, 2006 | 01:50 PM
YT1300's Avatar
Turning and burning
There was a technical bulletin in the US with regards to squealing brake pads - do a search on this site and look for the Sticky in the Tech Support section of this site.
Old Jan 18, 2006 | 02:16 PM
herbert's Avatar
Scarboro Mazda replaced my pads (front I think) when I complained. They gave me no grief whatsoever. Unfortunately, they started squeeling again. I asked about it at my next oil change and they said they would lubricate them which worked for about a day. I'll complain again next time but I'm not sure that they'll do anything about it a second. The noise is a little embarrassing to the least.
My advice to you is to try a different dealer if you want to get it done and take the above-mentioned bulletin into them.
Old Jan 18, 2006 | 09:58 PM
CrackerJax's Avatar
same thing here, Avante replaced my break pads when i mentioned some noise. They said there was a bulletin or something. The noise did go away, but i think it came back shortly, so i just accepted it. Now my car has been put away for the winter.
Old Jan 18, 2006 | 10:44 PM
thaiboyrx8's Avatar
Thank you for every advice.
Old Jan 19, 2006 | 12:32 AM
rotten42's Avatar
Mentalhealth is overrated
Don't put up with that answer. Mine made noise and I had them replaced. They started making noise again and they first said they would not replace them...that's when I told them that I would take the issue up with Mazda Canada. They then replaced them for a second time. If they make noise again before the warranty is up, I will go back again and demand they change them. I don't buy the "because they are metallic brakes" arguement. There are other cars out there that have these brake pads and don;t have this problem.
Old Jan 19, 2006 | 02:12 AM
thaiboyrx8's Avatar
thanks again rotten42 for your advice.
