Canadians, check your Xenon Washers!
Old Jan 15, 2006 | 10:21 PM
StealthTL's Avatar
Post Canadians, check your Xenon Washers!
My headlight washers were pretty tame...slow to pop out, with a weak dribble of fluid.
Recently took off the bumper to install some bits, and found the washer pipe was kinked badly. After cutting out the kinked bit and reassembling, the washers are 100% better!
The hose was too long, so instead of coming down the fender then forward, it bent backwards, cutting off the flow.
The kink was immediately behind the passenger sidelight, if you removed the four plastic screw/plugs in the the wheel area, you could see the hose and connector. It's a big black plastic hose about 1/2" across.
If yours seems weak check it out!
(I've never used much washer fluid, but I checked yesterday, and my reservoir is now empty!)
S
Old Jan 16, 2006 | 08:04 AM
HELAS's Avatar
Kal-El Is The One
Thanks for the advice! Will do tonight!
Old Jan 16, 2006 | 10:51 PM
YT1300's Avatar
Turning and burning
I get a tidal wave of wiper fluid every time I flick the washers and my lights are on. I guess I don't have this problem with the kinked tube...
Old Jan 17, 2006 | 08:14 AM
Redshift's Avatar
Spinning Dorito Junkie
My car sprayed out enough fluid to cover the front of the car.
I pulled the fuse for the headlight sprayers the same night I brought the car home. Haven't had to worry about the stupid things for a couple of years now.
Old Jan 17, 2006 | 03:11 PM
AC_SB's Avatar
How do the headlight washers work? Is it in conjunction with the windshield wipers? On my brothers XC90, the headlight washers operate every 5th time you spray the windshield...does the RX8 operate on the same principle?
Old Jan 17, 2006 | 03:13 PM
04RX8chk's Avatar
yep - but the headlights must be on for the sprayers to work. They don't work with the daytime running lights.
Old Jan 17, 2006 | 03:21 PM
AC_SB's Avatar
Sounds verrrrry cool...cant wait to try and wash my windows and run in front of the car just to see em pop up!!
LB2739
Jul 9, 2019 02:25 AM
arexatemate
Oct 9, 2015 06:23 PM
Forevermore
Sep 20, 2015 01:04 PM
RAE008
Sep 19, 2015 02:24 PM
