Water temp adapter
Old Jan 4, 2006 | 04:41 AM
gerry76's Avatar
Water temp adapter
Hi,
I need of a water temp adapter to connect the sender of my gauge.I have seen that they exist of several dimensions,1"-1,25-1,50.Which it is that right one?Thanks for your help!
Old Jan 4, 2006 | 06:33 AM
expo1's Avatar
He's as bad as Can
RacingBeat has one.
http://www.racingbeat.com/resultset....rtnumber=11493
Old Jan 4, 2006 | 04:45 PM
truemagellen's Avatar
Attracts tree branches
mazdaparts sells the racing beat one as well for a bit less pic should be up soon
http://www.mazdaparts.com/ProductDet...000-1135401299
if you need gauges try this:
http://www.mazdaparts.com/SearchResults.jsp
water temp one in the description...high end defi stuff
Old Nov 20, 2008 | 02:40 PM
eva02's Avatar
so, what size do we need? i've seen some universal adapters. are those good?
Old Nov 20, 2008 | 02:53 PM
seikx8's Avatar
Is this title ok?
I got my 34mm universal one from here: http://www.glowshiftdirect.com/Water-Hose-Adapters.aspx
The RX8 radiator pipe is 35mm, I measured. The 34mm was a bit loose but the hose clamps included have no problem clamping it tight. So 36mm might be a better choice if you don't mind a bit tighter and harder to slide in.
Racing beat one is the most easy to install. So choose your pick
Old Nov 21, 2008 | 03:26 PM
eva02's Avatar
where did u install the sensor at?
Old Nov 21, 2008 | 03:38 PM
eva02: see my sticky thread in the Interior Electrical subofurm.
Here's a pic from the thread showing the location of my RB adapter.
Digitz0070
55
Jul 25, 2017 08:40 PM
FubarI33t
Sep 28, 2015 08:45 PM
DG07
Sep 28, 2015 10:58 AM
Learners_Permit
Sep 27, 2015 07:38 PM
Digitz0070
Sep 25, 2015 10:58 PM
