powerworks super charger info
Old Dec 16, 2005 | 08:09 PM
toca's Avatar
i just got done talking to these guys in person and got all the info in this kit.
this kit uses stock ecu with bigger injectors. only run 4 psi but uses a big supercharger. they have had no problems with this kit at all so far and going to release it feb or march 2006 for around 4k the power out put for this kit is 230whp
the kit looks very clean in person im going to get this when it comes out
Old Dec 16, 2005 | 08:13 PM
is this the one from sema with adifferent intercooler set up or is this anoterh company with similar setup?
Old Dec 16, 2005 | 08:26 PM
toca's Avatar
it same on but this is the final version of it what u see is the 1 there going to release
Old Dec 16, 2005 | 10:20 PM
rkostolni's Avatar
How is fuel management handled?
Old Dec 16, 2005 | 10:37 PM
toca's Avatar
stock ecu with bigger fuel injectors
Old Dec 16, 2005 | 11:01 PM
IZoomZoomI's Avatar
Boost needed
Huh?
Old Dec 16, 2005 | 11:02 PM
IZoomZoomI's Avatar
Boost needed
I wonder does this mean they are planning to reflash the stock ecu... I can't imagine the same ecu running my car n/a right now w/o any tune or change can run a s/c.
O and what was the change between this kit and the one at sema? Thanks for the updates though.
Old Dec 16, 2005 | 11:05 PM
his first response was saying this is the company i was refering to as being at sema and this is the final release version.
they are not changing the pcm maps because the maps are broad enough to handle this level of boost when using bigger injectors
Old Dec 16, 2005 | 11:09 PM
IZoomZoomI's Avatar
Boost needed
^^^ thnx for the clarification. Didn't they mention they were using a different octane fuel also?
Old Dec 16, 2005 | 11:11 PM
i wouldnt use anything lower than 91 or whatever the highest premium is your area
Old Dec 16, 2005 | 11:14 PM
toca your signature picture is too large please reduce the height of it
Old Dec 16, 2005 | 11:16 PM
IZoomZoomI's Avatar
Boost needed
I see. So no tuning would be needed? Hm not bad good for someone that is looking for bolton and go performance.
Can't really tell from the pictures but when you seen it at sema were they using a twin screw s/c or a roots?
Old Dec 16, 2005 | 11:26 PM
its a roots se the thread here https://www.rx8club.com/series-i-major-horsepower-upgrades-93/power-enterprises-supercharger-sema-75818/
Old Dec 16, 2005 | 11:31 PM
Moostafa29's Avatar
Storm Trooper
Even with the crappy CA gas? I'd be a little scared.
Old Dec 16, 2005 | 11:34 PM
IZoomZoomI's Avatar
Boost needed
Old Dec 17, 2005 | 08:07 AM
RX7TT's Avatar
Toca, It's look great! Do you know how's the torque plot?
Old Dec 17, 2005 | 08:52 AM
toca's Avatar
the tq is 200kw dont know what that is in tq but thats the number this kit uses a big blower to gets its power and yes the car is running off 91 octane the car only running 4 psi but with a big supercharger its giving them power the ecu is all stock no flash just with the big injectors they said they have yet to have 1 problem with this thats why there going to release feb ot march 06
Old Dec 17, 2005 | 10:36 AM
Moostafa29's Avatar
Storm Trooper
Just out of curiositly, what state's 91 octane were they testing this on?
Old Dec 17, 2005 | 07:03 PM
brillo's Avatar
Go Texas Longhorns!
I can't wait to here the reports on this one, I have a really hard time buying you could boost a car with no change in the engine management, most due to the really aggresive timing which I would think you'd need to back off.
Not saying it can't be done, hell, if they have, more power to them. They appear to have designed the kit and boost levels to fit that strategy.
Hopefully we can get some first person impressions soon.
Old Dec 17, 2005 | 08:28 PM
they are in cali
Old Dec 17, 2005 | 10:50 PM
xrider01's Avatar
127.0.0.1
just as long as you don't get ANY kind of gas from an ARCO/BP gas pump here in cali (even if premium) you should be fine
Old Dec 18, 2005 | 01:37 AM
QBallz's Avatar
I wonder how well that intercooler really works right there. And also 4k seems a bit expensive for no engine management.
Old Dec 18, 2005 | 07:37 PM
cerveza27's Avatar
Did you happen to get a close up of that spec sheet they had on the car? If its the same one I saw at SEMA its running 6.5 psi boost, not 4. They told me four at SEMA as well and then you look at the spec sheet and it says .45 kg/cm^3. I'm curious to know what boost they are pulling power numbers from, if its 4 psi the spec sheet they have on the car isn't valid.
Old Dec 18, 2005 | 09:00 PM
gh0st's Avatar
i spoke to a tall filipino guy with long spiky hair at D1 on sat. the info i got was quite different then what was given to you. he told me they were making 260 to the wheels and 200 kw of torque. he also said they were using stock injectors though. i asked him twice to make sure and he stuck to his guns on both occasions. he claims he drives the car everyday and that he knew the car well. maybe he was a bit slow
denward
Old Dec 18, 2005 | 10:00 PM
toca's Avatar
hmm i talked to the shortor guy not the spike guy it said 260 crank and 230 whp with bigger injectors lol but eve so what ever its proved it works im still going to get it
