Squeaking in front suspension when cold
Old Dec 14, 2005 | 03:15 PM
crimson-rain's Avatar
Anyone have this issue? In the morning it's been pretty cold here in VA but why would that affect my suspension?
When I go over a speed bump or hit a dip in the road, the front suspension squeaks like an old bed. I went over a few speed bumps in my apartments and it's always the front. The back goes over the bump and no squeak. Funny thing is that after driving around for a while it won't make those noises.
Anyone know what that could be?
Old Dec 14, 2005 | 05:21 PM
Go48's Avatar
Re-torque the nuts and bolts of the suspension components to spec, especially the sway bar. However, it may just be a cold rubber component rubbing on metal or another rubber component which will be difficult to diagnose.
Old Dec 14, 2005 | 05:32 PM
expo1's Avatar
He's as bad as Can
You still have the stock front sway bars?
Old Dec 14, 2005 | 08:06 PM
brillo's Avatar
Go Texas Longhorns!
check the swap bar endlinks nuts
Old Dec 15, 2005 | 06:12 AM
Go48's Avatar
Let's say it again. Check the sway bars. Sheeeesh.
Old Dec 15, 2005 | 07:37 AM
yep. Are the bushings rubber, polyurethane, or something?
Old Dec 15, 2005 | 07:49 AM
expo1's Avatar
He's as bad as Can
They are rubber and shouldn't make any noise IF the nuts are tight.
OEM bushing
As mentioned above check all aspects of the front suspension for proper torque. I had a similar noise, but that was do to dry aftermarket polyurethane sway bar bushings.
Old Dec 15, 2005 | 04:34 PM
Thanks and thanks for the pic. I'll check it out.
Old Dec 16, 2005 | 02:26 PM
Nubo's Avatar
Lubricious
OEM bushing
Mine makes a squeak on the first speed bump on a cold day. Thanks for the tip! Lol, for a moment I couldn't figure out what that "component" was. -- Torque wrench!
Old Dec 16, 2005 | 03:48 PM
expo1's Avatar
He's as bad as Can
It's not a torque wrench, It's a Sidewinder speed wrench, comes in handy at times.
http://www.aircraftspruce.com/catalo...nderwrench.php
Solidtrance
22
Sep 4, 2015 12:47 PM
akagc
Aug 11, 2015 07:07 PM
AussieGray
Jul 16, 2015 03:58 AM
