P0171: System too lean
Old Dec 10, 2005 | 12:46 AM
RX8 Brunei's Avatar
Rotary Lover
From: Brunei: Where Ricers show off their fugly rides
Lightbulb P0171: System too lean
need opinion on this.
Refering to my previous post https://www.rx8club.com/series-i-tech-garage-22/starting-problems-75540/. My 8 recently had starting problem (hard start) & engine stalls at idle.
This is what i found out by retreiving DTC with sCANalyzer : Pending P0171 i.e. system too lean. Attached below is DTC Table. This might give me idea of what's going on with my 8.
Since i've reset ECU & KAM long ago, so there's no CEL/MIL been stored in PCM. I retrieve this "P0171" code (1 drive cycle) while the car is station & engine start by the help of alcohol.
I need to drive the car by next week (Drive Mode), so that i can throw CEL blinking & flashing all the way. Then i'll know what DTC appear when i retrieve it.
Stay tune & wish me luck .
Attached Thumbnails P0171: System too lean-dtcp0171.jpg
Old Dec 10, 2005 | 02:40 AM
i would pull out the maf sensor and clean it with electronics cleaner. easy to do. if i recall your car was flooded.
it is a start.
Old Dec 10, 2005 | 07:31 AM
Rasputin's Avatar
Can you post the freeze frame data (all the engine parameters at which the error happens) given by the sCANalyser?
Fabrice
Old Dec 10, 2005 | 03:14 PM
r0tor's Avatar
it is a start.
i 2nd that
Old Dec 11, 2005 | 07:32 AM
RX8 Brunei's Avatar
Rotary Lover
already done deflooding procedure more than 20 times.
Old Dec 11, 2005 | 07:36 AM
RX8 Brunei's Avatar
Rotary Lover
Fabrice
No freeze frame data appears. That's why i've to follow the "drive mode" procedure so that CEL/MIL appear. Give me few more days. I'll update sooner or later.
Old Dec 11, 2005 | 07:40 AM
RX8 Brunei's Avatar
Rotary Lover
it is a start.
i've done it using contact cleaner. the result still the same. the only way is to swap with my friend's MAF sensor. i'll proceed on that later after i get those CEL.
Old Dec 11, 2005 | 10:23 AM
crossbow's Avatar
Are you running with an intake? The p0171 cel is one of the most common cel's seen in the 6 for those running intakes.
Old Dec 11, 2005 | 09:05 PM
RX8 Brunei's Avatar
Rotary Lover
yup. be4 i was using HKS racing suction kit. used it around 22,000km, now back to stock. i'm not sure if the problem comes from MAF sensor.
Old Dec 11, 2005 | 10:17 PM
j9fd3s's Avatar
yep, put the factory intake on and the cel will go away....
Old Dec 16, 2005 | 12:02 AM
RX8 Brunei's Avatar
Rotary Lover
Done that. Last night i tried to start the engine, to see if there's new DTC occur. Juz like a member said that P0171 only appear in 1st drive cycle. After i clear the DTC off, no DTC after retrieve.
My friend said that JDM ECU originally set the AF slightly lean. AF will be more leaner when replace the stock airbox to aftermarket intakes. Can anybody make me clear about this?
Last night, i don't manage to drive the car (gas tank nearly empty). But i'll drive it tonite.
Old Dec 16, 2005 | 12:10 AM
RX8 Brunei's Avatar
Rotary Lover
About this AF thingy.... i have in my mind about TurboXS DTEC FC. Since there's no ECU flash at the dealer, i'll go for this stuff when it's confirm that no parts/sensors are malfunction. Juz my thought. Any recommendation?
Old Dec 17, 2005 | 07:24 PM
Hymee's Avatar
Race Steward
Any exhaust changes - eg O2 foolers, CAT replacment/removal???
Cheers,
Hymee.
Old Dec 17, 2005 | 10:40 PM
Im_DANomite's Avatar
I love GOOOLD
you're getting un-metered air into the engine. i'd check vacuum lines, loose intake connections, etc. spray some brake clean on suspected areas and see if the rpm or engine changes its speed. i'd start by doing that first. no leaks found means it's something electrical.
Old Dec 19, 2005 | 10:50 PM
RX8 Brunei's Avatar
Rotary Lover
Cheers,
Hymee.
I'm replacing the CAT converter pipe (already dead) with a custom CATless direct pipe. It's still there coz i don't plan to change it back to stock & very pricey to get new CAT. I didn't install any o2 foolers. Thanks for the feedback Hymee.
Old Dec 19, 2005 | 10:54 PM
RX8 Brunei's Avatar
Rotary Lover
Thanks bro. Will do it l8r on.
Old Dec 19, 2005 | 11:12 PM
RX8 Brunei's Avatar
Rotary Lover
OMG. I 4got to mention that i've test drive the car last friday night. Sadly i don't get any CEL coz i only manage to drive it 1.5km only. That night the road was very congested/rainy condition, so i give up. As u all know that i had to press the accelerator pedal constantly to make the engine rev at least 2,000rpm (engine will stall if rpm drop below 2000rpm). I'll try to drive the car at midnight on this weekend. Distance target 15-30km at highway. Hopefully i'll get CEL from this upcoming attempt.
Old Dec 20, 2005 | 12:24 AM
Hymee's Avatar
Race Steward
I would have thought it would already have a CEL if it is running that poorly!
Cheers,
Hymee.
Old Dec 20, 2005 | 10:32 PM
RX8 Brunei's Avatar
Rotary Lover
Cheers,
Hymee.
Yeah i thought so. It's really weird.
Old Dec 20, 2005 | 11:46 PM
RX8 Brunei's Avatar
Rotary Lover
4got to take a pic of sCANalyzer monitoring the details of my 8. All i remember is whether the MAF or AFR is more than 15.0+, the highest is 19+. And that's too damn lean am i right?
Old Jan 2, 2006 | 08:43 PM
RX8 Brunei's Avatar
Rotary Lover
Confirm MAF sensor malfunction.
Old Jan 2, 2006 | 08:59 PM
Hymee's Avatar
Race Steward
So do you have a mate with an RX-8 you can try swapping the MAF sensor with? Simple to do - undo 2 screws and a connector. If that fixes it then you can order one from spare parts. Don't forget when it is all fixed, you might have to reset the CEL (or you didn't get one?? - weird) using your sCANalyser.
Old Jan 2, 2006 | 09:21 PM
KJ238's Avatar
Air + Fuel + Spark = Boom
He's gonna do that today... He practically knows every rx-8 in this country.....
I just hope that it is as simple as a MAF problem.... Good luck bro
Old Jan 2, 2006 | 09:44 PM
yiksing's Avatar
the giant tastetickles
Looks like a turn of luck for you eh RX8_Brunei, good luck
Old Jan 3, 2006 | 06:43 AM
tems900's Avatar
can buy e MAF in S'pore for SG$252 include tax, just replace it today. Have driven the car for 2yrs , 37000Km, having problem starting e car since 3 weeks ago but no CEL, had tried all the deflooding procedure, change battery, new spark plug, put back e OEM CAT midpipe, now MAF & i hope it work, if not i need to remove the Trust CAI & put back e OEM airbox, if all e change still don't help, i need to sent my ECU back to KnightSport for retune.
