Pain in the Ass rattle in Pass. Door!
Old Dec 5, 2005 | 10:31 PM
LoveMy8's Avatar
Smile Pain in the *** rattle in Pass. Door!
Whats up everyone? Since I have own this car I have had a rattle that only seems to come along when it is cold out. Well, since I live in Jersey, I get to hear that "lovely" noise 4-5 mos of the year. Well anyway, the rattle is in the pass. side door. It sounds like styrofoam or something similar. Even when I play music the rattle is there. It sucks. Now I want to know if anyone has any idea of what it might be and how it can be fixed. Dealer tells me they cannot reproduce the noise. But I rather fix it right the first time anyway. Also, if anybody has a link or information on removing the pass. side door panel I will greatly appreciate it, if you shared your 411.
Sorry for the long post
Thanks in advance,
Rich
Old Dec 5, 2005 | 10:36 PM
truemagellen's Avatar
Attracts tree branches
there is a TSB on this...but personally I think the TSB is shlock as they have attempted to fix this
4, yes 4 times now! and they are all smart guys...there is something weird going on and it just doesn't want to go away
don't worry though it is all warranty work
Old Dec 5, 2005 | 10:45 PM
LoveMy8's Avatar
Thanks for the info True:
BTW nice Avatar. Is that your car in the pic? If so, how do the fogs, parking lights, sidemarker and headlights match up? I like your set-up, could you supply some info on the bulbs you used and where I can purchase them? I would like to do the same exact set-up if you don't mind.?
Thanx again,
Rich
Old Dec 5, 2005 | 11:00 PM
RedSheDevil's Avatar
.:. causing mischief
i had the rattle too. took apart the door (very easy IF you know where the clips are). i ended up moving the foam a little bit because it had come undone from the stupid pin that it sits on.
ill see if i can dig up my door diagram for ya ...
cuz now my drivers door is rattling!
Old Dec 5, 2005 | 11:20 PM
ok found the diagram, but its gonna take some work-arounds to get it in a postable format. ill do this tomorrow ...
Old Dec 6, 2005 | 01:16 AM
Parmer8's Avatar
I've got a similar rattle on my passenger door too. Mine is from the silve RX8 piece on the door sill. The end is coming apart from the sticky tape and it rattles the door sometimes.
I dynomat the door interior a while back and the sound hasn't gone away. My guess it's the from the door sill.
Old Dec 6, 2005 | 07:48 AM
guy321's Avatar
Humpin legs and takin nam
What, no love !!?
Old Dec 6, 2005 | 08:29 AM
^ hey dude, i was tryin to keep you out of it
all images supplied courtesy of guy321, pimpest owner and helper outter of all in need.
and most famousest leg humper of them all!!
that better?
Old Dec 6, 2005 | 08:36 AM
ok here are the pics (again courtesy of guy!) And i did end up getting the door clip removal tool.
Old Dec 6, 2005 | 08:38 AM
did you check that silly piece of foam? mine had some staples in it that were rattling between the foam and the door skin. but by the time i got to them, the pin that the foam was on was no longer holding the foam to the skin. really shoddy design imho
Old Dec 6, 2005 | 09:25 AM
guy321's Avatar
Saying that I helped would have sufficed !
that better?
Old Dec 6, 2005 | 09:35 AM
oh, and he helped too!
Old Dec 6, 2005 | 09:37 AM
Thanks in advance,
Rich
looks like RSD and the other guys helped out with the rattle
as for the lights
the clear corner light and inner light (lights closest to center mass) are LED 194s in Hyper white, they don't match perfectly but are close, the LEDs are whiter than the stock HID headlights, I bought them from autolumination and they look great but I've heard the PIAA versions last much longer and have a warranty although they cost much more.
I also have installed Hyper white foglights which are the H11 bulbs but as you can see from the pic I didn't turn those on.
I also have Hyper white front turn signals but they require a load equalizer on the line to combat the ecu induced 'triple blink' that occurs when you do not have incandescent bulbs installed a set wattage.
The LEDs are relatively easy to install from under the hood, although you will probably cut your hand or need a small child to install them
The fogs require a removal of the front bumper, very easy actually
Old Dec 6, 2005 | 09:41 AM
yea id like to change my fogs someday to a whiter light.
and EVERYONE says taking off the bumper is so easy im starting to wonder if there is a sticker under there that says "now go tell everyone this is easy to remove"
Old Dec 6, 2005 | 10:27 AM
Dark8's Avatar
Ride Naked!
It is only easy the second time you take it off.
Old Dec 6, 2005 | 10:30 AM
^ LOL, good to know!
Old Dec 6, 2005 | 02:10 PM
caribbean_spice_boy_73's Avatar
Work in Progress
nice post .. i had the same thing.. going to do that this friday....
Old Dec 6, 2005 | 03:54 PM
Transam kid 01's Avatar
The anti-ricer
Thanks in advance,
Rich
Will this happen to everyone, or does it depend on the package you get or something
and where in jersey are you?
-Sean
Old Dec 6, 2005 | 10:24 PM
LoveMy8's Avatar
-Sean
Thanx for all the help everyone!
I live in Hillsborough
-Rich
Old Dec 21, 2005 | 12:37 AM
REL_RX8's Avatar
2005 RX-8 GT Sunlight Slv
I noticed a rattle in my driver's door too. Seemed to come along when it get's really cold outside.
I can make the rattle go away by pulling on the side panel of the door. (I do this while I'm driving, rattle goes away instantly when I pull) The rattle comes back right when I let go of the side panel.
Has anybody else tried this? All I know is that I'm about to kill myself if this continues, it's getting really aggravating.
Old Dec 21, 2005 | 12:50 AM
Crazy Rx-8 Driver's Avatar
XYELLR8
i notice a rattle only when the audio system is on.. even at very low volume the rattle will occur... grrr it is so annoying.
weill this be covered under warranty ???
Old Dec 21, 2005 | 01:00 AM
REL_RX8's Avatar
Same here, all it takes is a TAD of bass, and the damn thing rattles.
Old Dec 21, 2005 | 07:05 PM
mikeb's Avatar
100% Italian
rel
I have the same problem as you
im gonna have the dealer look at it next time I get a oil change
Old Dec 28, 2005 | 06:18 PM
Charles R. Hill's Avatar
Owner of BHR
If some of you take your own door panels off to fix the squeak you may also want to tighten the 4 bolts that secure the power window rails to the door liner, as that is the source of the cold weather rattle or knock when you operate your windows. I intend on fixing both noises next Spring.
CRH
Old Jan 12, 2006 | 09:32 PM
Torchmonkey's Avatar
I've had the car less than 4 months...only 2400 miles and the frickin' thing has this door rattle. Not when it's cold...not when the radio plays...all the time! I have printed out the directions (thanks!), but honestly, I have to break something twice before I learn to do it right (no, I don't work for NASA). I'm gonna try to nail down the location and have the dealership find it.
