Post shutdown fan???
Old Jul 29, 2003 | 06:52 PM
tank's Avatar
I've had the car for almost a week and absolutely love it!!! I know some folks have mentioned that after turning off the car the fan runs for sometime. Mine does this, however it seems to be completely random as to when it occurs. For example the past two days after driving home from work, the outside temperature was the same, similar drive conditions, the fan came on the first day and did not come on the second day after shutting down. Any thoughts or input would be greatly appreciated.
Old Jul 29, 2003 | 06:54 PM
Toadman's Avatar
Nomad Mod
It has little to do with ambient outside temperature. The thermosensor triggers the fans based on coolant temp and engine load if driving(i.e. A/C, etc.).
jd62's Avatar
Old Fart
I've noticed the same thing. It was 101 today, and the fan didn't come on as usual. Maybe it takes a little while for the temp to rise after you shut it off, and I leave the garage and don't notice it. However, sometimes the fan comes on as soon as I shut off the car. I'd like to hear some more experiences too.
Old Jul 29, 2003 | 06:59 PM
khoney's Avatar
FX8TED on my RX-8
Same here - sometimes doesn't come on right away. I don't think it's anything to worry about.
Old Jul 29, 2003 | 07:10 PM
seikx8's Avatar
Is this title ok?
Well, you are not alone. I experienced that as well which I've mentioned in this thread. With all the feedbacks, I'm not worrying about it right now. But if the battery every die, then that will be a different story.
Old Jul 29, 2003 | 07:22 PM
tank's Avatar
Thanks for the reasurrance, I'm still not totally comfortable with the fact it comes on so randomly understanding that it is triggered by the thermostat, however it seems to me that under similar driving circumstances and engine load the fan should be triggered consistently. Oh well... it doesn't sound like I should lose any sleep over it
Old Jul 29, 2003 | 08:07 PM
Puppy1's Avatar
Pure Unadulterated Fun
On our rally in the mountians of San Diego all 5 of the RX-8's were subjected to the same steep climb and 93 degree temps, yet when we stopped to take pictures at the top, my car was the only one with the fan going. And it stayed on for a very long time. What's up with that?
Old Jul 29, 2003 | 08:19 PM
mikeb's Avatar
100% Italian
The first day I drove mine the fan would go on and off often. But, I'm happy it seems to be normal
Old Jul 29, 2003 | 08:38 PM
RX8-U-UP's Avatar
The owners manual says that once the sensor turns the fan on, it will stay on for approximately 10 minutes. I have noticed that if I turn the key back to on, without starting the car, and then back off, it will reset the fan and turn it off. I don't think this is necessarily good, I did it by accident. Don't think its anything to worry about, unless you do something to prematurely turn it off, like I did by accident.
Old Jul 29, 2003 | 09:59 PM
eccles's Avatar
Prodigal Wankler
It's also possible that the fans had been running for the last few minutes before you arrived home, and thus did not need to come on again after you shut down.
Old Jul 29, 2003 | 10:16 PM
jd62's Avatar
Old Fart
Ah hah! I hadn't considered that. I had assumed the fan only worked when the engine had shut down.
Old Jul 29, 2003 | 11:22 PM
Napboy's Avatar
Sho'Nuff
I don't know if this helps, but after having the car for 5 days now, the fan no longer comes on after shut off. This could be due to cooler temps or the engine is being cooled more properly now that it's being broken in (btw, I have 300 miles now). I suspect the fan will begin running less and less after shut off.
Old Aug 4, 2003 | 05:03 PM
RX-Nut's Avatar
8 the HARD way.
Weird.. I got my first fan action.
I walked away from the car and was like WTH!? The car's still running! I have the keys in my hand... Am I crazy? Did I leave the A/C going.. ?!?
So I sat there and waited until it stopped.. It took a while.. a good 2-3 minutes. Panicked me for a bit, I thought if it don't turn off, wont it kill the batt? Hmmmm
So I came to the forum to see if it was normal, and I guess it is.. I guess because it was rather loud, it shocks you.. Weird..
Old Aug 4, 2003 | 05:07 PM
neofreak's Avatar
94-95 RX-7's did the same thing, nothing to worry about.
(93's didn't)
Old Aug 4, 2003 | 06:20 PM
MikeW's Avatar
Is there a post shutdown coolant pump?
Can you feel any air coming out of the fender air outlets?
Old Aug 4, 2003 | 06:26 PM
eccles's Avatar
Prodigal Wankler
[list=1][*]No[*]Yes[/list=1]
Old Aug 21, 2003 | 09:45 PM
Elara's Avatar
My fan did this for the first time today, and thank god I remembered this thread because it startled the heck out of me. I took the key out of the ignition, and the fan started up. Could it be any louder, you think? Had me completely freaked out for a few minutes.
Old Aug 21, 2003 | 10:24 PM
Wolfer's Avatar
I've only had the fan come on 2 times after I stopped the car. You can feel the heat coming out of the side vents. I just stood there thinking how neat it will be when its cold outside and you can see the steam coming out the sides when you stop. But since it'll be dry heat I guess you won't see anything.
Old Aug 21, 2003 | 10:34 PM
loco4rx8's Avatar
BSG 75
I've never heard the fan come on. Had the car for a week now with over 500 miles on it. I want to hear the fan too!! :p
Old Aug 21, 2003 | 11:56 PM
eccles's Avatar
Prodigal Wankler
Move south! :p
Old Aug 22, 2003 | 12:45 AM
Pete's Avatar
It's common .... nothing to worry about. I get it all the time
Old Sep 9, 2003 | 10:30 AM
RX8-TX's Avatar
Senior Geek
Fan going waco! while driving
OK, I found this thread and thought it might be appropriate to post my question here, thus leaving a consistent trail of information on a single place. Here is what happened:
I was driving from work to school last evening. Avg speed 35mph, temp: 90ºF, traffic was not so heavy but there were some stop-n-go situations, and the AC was on 1 (recirculate) front vents.
I noticed after turning the stereo off, that the engine fan was going on for a couple seconds, then off, on...then off. All the way until I parked the car.....and the fan didn't come on.
OK, now....my speculations an fears:
1. Could it have been the AC compressor turning on and off ??...I could hear a 'realy' switch sound everytime there was a fan off / on. However that would not explain the 'fan' noise.
2. Is it common for the engine fan to come on/off several times in a lapse of 20 seconds??
3. Ahhh....yes, is it normal? have any of you noticed it?
4. Please tell me everything is alright! and I'll send you a Xmas present (well, maybe just a postcard!)
M.-
IamFodi
Series II Interior, Audio, and Electronics
28
Oct 31, 2018 06:37 AM
