Watery break sound.. anyone knows???
Old Nov 30, 2005 | 04:05 PM
jyenc's Avatar
Hello all:
I m pretty new to the rotary, and the truth, i m not very good with cars either... but does anyone hear this water flow sound when they start the engine??? and when i am waiting for the car to warm up, i step on the gas, hear this water flow sound coming from inside of the stereo or something... anyone know if this is normal?
Also, when i back out from my garage, i also hear this hummm sound, like something engages together,,, wat's that??
Maybe i m just paranoid, but curious about these sounds... can anyone help?
Old Nov 30, 2005 | 04:18 PM
truemagellen's Avatar
Attracts tree branches
yes sounds like it is coming from the gear box right?
you have a manual transmission right?
I believe it is just the sound of the transmission fluid fluid and/or excentric shaft churing about until it picks up speed, I don't know for sure though
so no based off this you aren't crazy
Old Nov 30, 2005 | 04:23 PM
ZoomZoomH's Avatar
Mulligan User
yes i hear that liquid 'splashy/swirly' sound too, but as long as nothing spills out from behind the stereo, i don't mind it
Old Nov 30, 2005 | 04:25 PM
jyenc's Avatar
Talking
hehe... that's true...
Old Nov 30, 2005 | 04:33 PM
Go48's Avatar
Originally Posted by jyenc
Hello all:
Could very well be air in the cooling system. Coolant flows through the heater core that is located behind the dash. Take the car to the dealer, tell hime exactly what you reported here and that should prompt them to bleed the air out of the cooling system. If they don't come to that conclusion on their own, politely suggest they do that.
Old Nov 30, 2005 | 04:36 PM
yep air in the heater core- it needs burped.
Old Nov 30, 2005 | 04:40 PM
ZoomZoomH's Avatar
Mulligan User
ah darn it, guess i need to have mine looked at as well
Old Nov 30, 2005 | 04:42 PM
Go48's Avatar
Missed that part with my last post. What you are hearing is probably the ABS system doing it's check. Not a problem.
Old Nov 30, 2005 | 04:52 PM
jyenc's Avatar
Unhappy
Thanks for the replies to all of you. So i guess this sound is not normal... time to go to the dealer.. man, i hate dealing with the dealers....
Old Nov 30, 2005 | 04:54 PM
jyenc's Avatar
Ohhhh.. forgot to mention... since the weather got colder, my coolant lights goes on, but after i drive it, it turns off again. I recently did oil change, and they refilled my coolant too... is this related to that sound that I have?? I hope not, but.... truth usually hurts
Old Nov 30, 2005 | 05:07 PM
i see no reason why you should make a special appointment. just wait until your next service and have them take care of it then. unless its driving you really nuts.
Old Nov 30, 2005 | 05:09 PM
jyenc's Avatar
Good idea... Thanks guys... really helped out... appreciated
Old Nov 30, 2005 | 07:29 PM
beachdog's Avatar
burping
https://www.rx8club.com/showpost.php...8&postcount=10
Old Nov 30, 2005 | 07:46 PM
RX8SaxMan's Avatar
I have the sound too. Can the air in the system cause any problems or performance degredation?
Old Nov 30, 2005 | 08:57 PM
beachdog's Avatar
Overheating if there is enough air to create a blockage or too much air is preventing the full coolant capacity.
Old Nov 30, 2005 | 09:16 PM
this sound is normal!
Old Dec 1, 2005 | 12:29 AM
Dethwalkin's Avatar
How do we decide when we need to "burp" it? I have heard this sounds in other cars I have owned too. Is "Burp" a tech term or....
Old Dec 1, 2005 | 11:59 AM
jyenc's Avatar
After the car is warmed up, this sound is gone... only at the early morning... so, i really don't know what this is... next service i'll just get it checked up, if this sound is still there after, then i guess it shouldn't be a problem.
Old Dec 1, 2005 | 12:26 PM
I've had this car for over a year and a half and have this sound occur just about everytime i start the car
I asked the service guys about it a long time ago, they said it was normal (and this service department is outstanding)
R3Dream
Mar 7, 2019 09:11 AM
R3Dream
48
Mar 12, 2016 01:44 PM
snowrydr01
Nov 23, 2015 09:40 AM
erikcamacho15
Sep 12, 2015 11:23 AM
