Whats that clunck.
Old Jul 28, 2003 | 11:55 PM
alarabie's Avatar
Whats that clunck.
Does your car make a clunk when you go from reverse to 1st. Mine has definite clunk, as if there is some sloppiness in the drive train, Its probably nothing but I just wonder.
Old Jul 29, 2003 | 12:12 AM
MrWigggles's Avatar
Re: Whats that clunck.
A lot of cars make a very pronounced engagement sound when going in and out of reverse. I didn't really notice it on my test drive but it was probably there.
-Mr. Wigggles
Old Jul 29, 2003 | 12:37 AM
JSG's Avatar
JSG
#2 to take delivery
Mine clunks from the right front wheel area just after pulling off in 1st. No idea what it could be.
Old Jul 29, 2003 | 12:50 AM
Napboy's Avatar
Sho'Nuff
I was gonna post this same topic. I have the same clunk. It's very distinct and it seems to happen only in first gear, especially when downshifting. I tried to replicate it, but I can't find the pattern. I know it's not from reverse to first though. Anyone?
P.S. Can the server for this forum be any slower?
Old Jul 29, 2003 | 02:00 AM
Lock & Load's Avatar
Thumbs up ADJUSTMENT IN YOUR CLUCTH
Most clucthes have to be adjusted after your 1st sevice i think thats the noise you are probably hearing the clucth plates can be adjusted, dont worry be happy.
Old Jul 29, 2003 | 02:56 AM
Digisan's Avatar
Alpha Powered
I noticed it too, but only after I intially start the car and put it in first. I wonder if it's the DSC kicking in when you start off, not actually working, just initializing? Just a guess...
D-san
Old Jul 29, 2003 | 10:13 AM
RodsterinFL's Avatar
yes, when I back out of the driveway and begin to roll forward in 1st - Clunk. The first time it did this was very loud. A family member heard it in the garage and asked later what that was. Since then it is like an AC compressor kicking in.
Old Jul 29, 2003 | 10:15 AM
Cylo's Avatar
'04 RX-8 GT Silver R/B
It says in the manual, that this is normal, and it is the car doing some kind of self test. Read your manual for specifics.
Old Jul 29, 2003 | 10:18 AM
rotary_it_up's Avatar
The clunk you hear when you first start moving in first or reverse is an ABS self test. Nothing to be concerned about. Many cars do this.
Old Jul 29, 2003 | 10:28 AM
RomanoM's Avatar
I Just Can't STOP!
Actually all cars do this. Is absolutely mandatory for cars with DSC (ESP).
Most cars do it when your up to speed, usually 35MPH, to mask the noise.
The proper thing to do is do the test as soon as possible.
If the car had an active booster, like the Lincoln LS, the brake pedal will actually fall away and vibrate.
Old Jul 29, 2003 | 10:32 AM
Napboy's Avatar
Sho'Nuff
The clunk I'm hearing is not the initial ABS test, unless it is gonna test itself several times throughout stop-and-go traffic. I think an earlier post is correct about the clutch needing adjustment. I hope this is covered under warranty. No worries though.
289shelby
54
Feb 3, 2010 12:43 AM
