Where did my coolant go?
Old Nov 21, 2005 | 01:46 PM
JonsToy's Avatar
Registered Rep
I bought my 2004 VR MT last December with 9500 miles on the odometer. Over the last year, I've put about 10,000 miles on the car, mostly stop-and-go city driving.
When July of this year came around, I noticed that funny-looking indicator on the dash representing low coolant would illuminate every once in a while, then go away. I checked the coolant level, and sure enough, it was low. I added fluid to the system to bring it back up to the proper level, and it ended up taking about a 1/2 gallon.
This past weekend, the dash light starts up again, so I checked the level and, yes again, it was low. This time it took 3/8 of a gallon to bring it back up to its proper level. That's almost a gallon of coolant within a year's time!
I haven't noticed any puddles under the car, the carpet on the passenger side isn't wet, and there's been no steam bubbling out under the hood. But I seem to be losing coolant. Is anyone else having to add coolant as if it were engine oil?
Old Nov 21, 2005 | 01:50 PM
Aseras's Avatar
that's not good, better take it in and have them check for leaks... hopefully it's just a hose and not a seal in the engine...
Old Nov 21, 2005 | 01:53 PM
Y&Y's Avatar
Y&Y
you probably did this, but I still have to ask. Check the radiator cap, when the engine is cool of course, and the radiator hoses. You must have a leak somewhere. Also make sure to add some water with your coolant. You don't want all coolant in your radiator and resevoir tank.
Old Nov 21, 2005 | 02:07 PM
Go48's Avatar
Possibly it is only leaking when driving on the road. Look for coolant residue around the hoses and engine housing joints. Also, there have been numerous reports of leaking water pumps, so take a look at the weep hole on the bottom of the water pump to see if you see an residue of coolant there. I would expect there to be residue on the inside of the undercover under the engine as well if the water pump is leaking.
The good news is that if your car does not emit white smoke from the tailpipes, the leak is probably not internal to the engine. But obviously the coolant is going somewhere since evaporation would not account for the quantity you are adding.
Old Nov 21, 2005 | 02:48 PM
therm8's Avatar
Bummed, but bring on OU!
Could be as simple as overflow when hot. After 20k miles I wouldn't be too surprised at adding some coolant. I think I had to add some around 28k. But you seem to have a persistent problem. I'd definately have the dealar look it over. Coolant and oil are 2 things you don't want to be losing, particularly on a rotary.
Old Nov 21, 2005 | 06:12 PM
1.3L's Avatar
The lack of any visible evidence could possibly mean your engine has an internal problem that is allowing coolant to get into the combustion chamber. It only takes a very small crack or failed gasket to allow the coolant level to go down gradually and without notice; no steam, no puddles. I had this happen to my '91 Explorer and it turned out that one cylinderhead had a very small internal crack that was allowing coolant into one combustion chamber and eventually out the tailpipe. I never saw any steam or puddles, but the coolant level would gradually go down at the rate of about 2 cups per week.
1.3L
Old Nov 21, 2005 | 06:36 PM
jimbo912's Avatar
My coolant light came on after about 10K also. Very little coolant left. I filled it and took it to the dealer. Thay fixed the hose and a clamp. No problems since,but my engine was flooded this morning. Flatbed to dealer,unflooded and upgraded plugs and battery. I thought I was immune from flooding(no problems for 20K). I've had it all-flooding,recalls,leaking fluids-but,man,do I love this machine and I keep coming back for more
Old Nov 22, 2005 | 08:35 AM
whenson417's Avatar
I have had about the same amount of coolant leak out of my car as well. I have yet to spot a puddle. Just last week when the temperature dropped my coolant level light came on and I had to add a fair amount of antifreeze. This week I have been smelling some antifreeze coming through the vents so I guess I should take it to a dealer to see if it all checks out ok.
Old Nov 22, 2005 | 10:48 AM
khoney's Avatar
FX8TED on my RX-8
My engine was replaced due to a coolant leak from the rear rotor housing. It was a Sept 03 build. Make sure they check the engine - probably not what's happening in your case, but better to be safe.
Old Nov 22, 2005 | 11:22 AM
Sea Ray's Avatar
I had to add some to mine around 15k miles when the light came on. No sign of leaks or engine problems either.
Old Nov 22, 2005 | 12:06 PM
strokercharged95gt's Avatar
mine just starting coming on periodically at 17k, still enough in the resivoir though I havent added any yet. No problems associated with it.
Old Nov 22, 2005 | 05:56 PM
Mikelikes2drive's Avatar
seems like alot of people are having this problem...
My 8 has about almost 21,000 miles on it and no problems with the coolant
and... a question... you should water with ur antifreeze/coolant? how much?
and my friend told me in emergency cases when your car needs coolant u can just add regular water... myth? harmful?
Old Nov 22, 2005 | 06:09 PM
Go48's Avatar
In most cases, the coolant/water ratio should be about 50/50. The reason for that is not just freeze protection, but also to allow for a boiling point of the mix higher than the boiling point of water alone. Of course, in a true emergency where you need to add something to the system in order to continue to drive, water will do just fine. But, when the emergency situation is over, it would be advisable to raise the coolant to water ratio in the system back to 50/50.
Old Nov 22, 2005 | 06:28 PM
rotarygod's Avatar
If there was a leak on the intake side of the combustion chamber near the intake ports, the chamber wouldn't be at a compression point and wouldn't leak pressurize or raise the temperature of the coolant system as it did when the coolant leaks were in the exhaust side of the engine in the 3rd gen RX-7's. It would put the system under vacuum more often and possibly suck the coolant out and then burn it in the engine. You'd never see it this way. It would just miraculously disappear. The coolant does go somewhere. You just need to figure out where. This would be very hard to diagnose.
Old Nov 22, 2005 | 07:07 PM
thanks for the info.
how often should one add coolant in their car because i havent added anything yet and have seen no need to.
Old Nov 23, 2005 | 06:13 AM
Go48's Avatar
You should only add it if you need to add it. You may lose a few ounces over time due to evaporation, but you should never have to add significant amounts like quarts. If you find yourself adding large amounts of coolant, there is a leak--either external or internal to the engine. Just keep an eye on the coolant overflow bottle and make sure the level is between the Full and Low marks.
Old Nov 23, 2005 | 11:09 AM
JonsToy's Avatar
Registered Rep
Thanks for the replies.
I think I'll let the dealer take a crack at this one.
Old Dec 2, 2005 | 12:52 PM
JonsToy's Avatar
Registered Rep
Just an update.
Took the car in yesterday for the 2 recalls and mentioned the mysterious coolant loss. They called back later in the day to say they wanted to put a pressure test on the cooling system overnight. Just heard from the dealer that a leak was found... in the water pump, similar to a few other posts I've read here on the forum. The good news is they have one on hand. The bad news is they won't have the necessary gasket until Monday.
So, I'm trying to get comfortable in the Pontiac Vibe rental. Gonna be a slow weekend!
Old Dec 2, 2005 | 01:38 PM
Umbra's Avatar
Best ratio is actually more around 70/30 (can't remember which is the 70 though). 50/50 does NOT provide the lowest freezing point, but of course the best mix for protection against corrosion may be different yet.
My light has come on recently when I start the car but it goes away before I'm around the closest corner (1/2 block). I should probably check it soon, I'm at 3600 miles.
Old Dec 2, 2005 | 01:53 PM
Mantis's Avatar
my coolant was sneaking out of the weep hole. they replaced the water pump. if you guys are seeing this, check the search under "green liquid" for more info. this site diagnosed my problem so I wouldnt have to deal with the service center second guessing me. this happened aroung 20k, and the seals couldnt handle the pressure over time allowing the coolant to sneak out.
Old Dec 2, 2005 | 07:13 PM
Y&Y's Avatar
Y&Y
Is that right? I've always assumed 50/50. But I don't have to worry about lowest freezing point. Where I live the coldest it ever gets is around 50F. And last night was like 56F.
Old Dec 2, 2005 | 10:25 PM
RX-Aight's Avatar
shaaaaaa...
have someone do a pressure test on the coolant system...
Old Jan 19, 2006 | 02:15 PM
rkostolni's Avatar
Every 3 months or so my coolant light would come on. I recently pulled off my turbo and found a definite leak at the intake manifold. I vaguelly remember seeing this prior to the turbo, although there wasn't as much of a coolant stain visible. So I don't think this is because of the turbo. Anyone who's losing coolant should definitely go in and get checked.
Now I'm just wondering how much of a problem this will be. I'm not sure if its something that needs to be fixed right away or if I can just deal with the inconvenience of adding coolant from time to time.
Attached Thumbnails Where did my coolant go?-100_0154.jpg   Where did my coolant go?-100_0151.jpg
Old Jan 19, 2006 | 02:27 PM
Brice-RX8's Avatar
Is the picture larger than a thumbnail, I can't seem to make it enlarge.
Old Jan 19, 2006 | 06:25 PM
rkostolni's Avatar
Pics are fixed now.
