question about flywheel
Old Nov 15, 2005 | 08:56 PM
kw1k's Avatar
Will my Low end TQ and high end go down with a lt flywheel?
Because i was talking to my cousin and he was telling me this.. but then again idk
help me out
Old Nov 16, 2005 | 09:26 AM
sti_eric's Avatar
help me out
A lightened flywheel reduces the amount of driveline loss. For a technical discussion of the advantages and disadvantages of a lightened flywheel, see this FAQ on NASIOC:
http://forums.nasioc.com/forums/show....php?p=9878792
Bottom line is, a lightened flywheel will increase the power you are putting to the ground (especially in lower gears) at a loss of driveability (may need to rev higher to get the car going) and possibly throwing a CEL (not sure if this is the case with the RX-8 or not).
Old Nov 16, 2005 | 10:47 AM
KYLiquid's Avatar
Oil Injection
its less weight to get moving, so while it doesnt MAKE power, it uses less power, so the engine will rev faster, allowing faster accel as well as getting you into your power band quicker, the effects are more noticable in lower gears, 1, 2, 3 will be a nice improvement.
Wurromurro
Sep 20, 2015 05:02 PM
yankeepicker
Sep 11, 2015 05:42 PM
TJSiegrist
Sep 10, 2015 09:29 AM
Rupanrx
Sep 4, 2015 06:44 AM
