6th gear vs Reverse: mis-shift?
Old Jul 26, 2003 | 10:47 PM
Lex's Avatar
Lex
I sat in a parked 6MT today at a dealership, and noticed that 6th gear and Reverse felt VERY close.
Is this a problem for you owners out there? How easy is it mis-shift?
I read a while back about someone having problems pushing the stick all the way over into reverse - is this true?
thanks.
Old Jul 26, 2003 | 10:49 PM
jd62's Avatar
Old Fart
I haven't had a problem myself, maybe others have. If you push straight down on the shifter, it goes into reverse just fine.
Old Jul 26, 2003 | 10:51 PM
brothervoodoo's Avatar
RainMan is Back
Hey Lex, actually I think it would be rather difficult to mis-shift. As indicated you phycially have to push the stick down and then crank it all way right and down. Don't worry about it.
Old Jul 26, 2003 | 11:05 PM
RodsterinFL's Avatar
Ditto from brothervoodoo
6th is regular shifting while reverse is push down and over.
Old Jul 26, 2003 | 11:14 PM
P00Man's Avatar
uhhhhh....hello?
yeah, he must not of known that and been sitting in a car that wasnt on
________
Lovely Wendie
Old Jul 27, 2003 | 01:38 AM
Puppy1's Avatar
Pure Unadulterated Fun
I've put it in 6th a couple of times already when trying to reverse, but I'm sure its practically imppossible to shift into reverse when going from 5th.
Old Jul 27, 2003 | 01:44 AM
tribal azn2's Avatar
amateur
Old Jul 28, 2003 | 10:52 AM
Smoker's Avatar
RX-8: Hmmmmmmmmmmmmm.....
Cool
now, now be nice Tribal. Don't turn this forum into another one of those "Flame every chance you get" forum.
Just remember how nice we were to you when you told us about not remembering to release the parking brake.
Old Jul 28, 2003 | 11:07 AM
RotoRooter's Avatar
If you want to reverse, you can mis-shift into 6th if you do not push the stick DOWN And OVER enough. No big deal.
IT IS NOT POSSIBLE TO FLIP INTO REVERSE instead of 6th. They have this locked out so you won't drop your tranny.
Old Jul 28, 2003 | 11:37 AM
Lensman's Avatar
_________________
My current car goes straight from 5th to reverse with no lock. I've only made the mistake once at 70mph and a microsecond later (spurred on by the awesome grinding noise!) I corrected it with no damage. You can't force it into reverse because the transmission rotation will lock you out. It sounds bad and isn't good though...
Old Jul 28, 2003 | 11:38 AM
blizz81's Avatar
Yeah, you'd have to do one hell of a rev-match to actually mis-shift into reverse. Even if you did push the stick down and accidentally shift in, it would probably crunch a tiny bit and lock you out. Not like building up metal shavings is good for the transmission, but of course a crunch here and there won't spell death for the car.
edit: what I wonder about is lock-out protection against mis-downshifts. If the redline fuel cut, etc, will just shut off the engine if you miss a downshift, or if as in RSX-Ss, you can actually blow the engine straight apart. That's probably a question I could answer if I had more rotary knowledge....
Old Jul 28, 2003 | 12:30 PM
TreknMazda's Avatar
Love it! Keepin' it!
I'm still a little gun-shy about going to 6th. The RX-7 side of my brain keeps telling me that is reverse. :p
Hopefully, when I'm driving the RX-7, the RX-8 side of the brain won't take control.
Would this be schizocarphrenia
Or schizophrxenia
Old Jul 28, 2003 | 12:53 PM
Midnight Flyer's Avatar
I have both a Miata 5 and 6 speed. The reverse from 5th is still back and to the right in both cars while the 6th speed is straight back. Plus there is a lockout so you can't misshift into reverse unless you move the car to neutral for a few seconds before shifting.
theblinkof
Oct 4, 2023 05:24 PM
nowakm99
Oct 9, 2015 07:10 AM
Luke.s
Sep 30, 2015 05:57 PM
Zube6115
Sep 30, 2015 12:57 PM
juicemantwon
Sep 26, 2015 12:30 PM
