Newbie
Old Jul 26, 2003 | 03:53 PM
Superfox1's Avatar
Newbie
I am really thinking hard about getting rid of my 99 Trans Am and getting an RX8....I am just worried I will be disappointed in the acceleration! Any thoughts?
Old Jul 26, 2003 | 04:16 PM
Pete's Avatar
Re: Newbie
Read up on the threads for more information on the RX8.
you'll find all the information you need.
If you want more information.....
Power
Renesis Rotary engine
250hp@8000rpms
159ft-lb@7500rpms
6-speed manual transmission w/ short throw shifter
6 Intake & 4 exhaust ports
9000rpm rev limit
high flow catalitic converters w/ dual exhaust
Suspension
Front double wishbone suspension
Rear: 12.3" diameter, .8" thick, Two-piston, fixed-position calipers (brembo).
Multilink rear suspension w/ 5 links per side
50/50 Weight distribution
Dynamic Stability Control (DSC)
ventalated 12.7" front disk brakes & 11.9" rear disk brakes w/ ABS & EBD (electronic brakforce distribution)
18"aluminum rims w/ 225/45ZR18 tires & tire pressure moniter system
BTW
Welcome
Old Jul 26, 2003 | 04:17 PM
umpuck's Avatar
u gonna worry about acceleration when u compare the trans am to the rx8 man :P
Old Jul 26, 2003 | 05:33 PM
Goldenhue22's Avatar
something called a test drive may come in handy
Old Jul 26, 2003 | 09:06 PM
Sputnik's Avatar
Re: Newbie
Well, of course, you will lose some acceleration (assuming you don't have a V6 Trans Am), and it will be different. It will be more of a peaky engine than a stump puller like the V8s. Being lighter than the TransAm will make up for some of the loss of torque and HP, but only so much. A test drive will tell you whether you can live with it or not.
But the balance and response of the RX8 will be that much better than the Trans Am. You might find that to be a nice change of pace. I had a Grand Prix GTP for a couple of years as my daily driver, and loved the torque. But it grew old, and I gave it up for a Miata. Even in city driving, the Miata was more of a fun package. And that car had more of a power deficit to the Grand Prix than the RX8 does to the Trans Am. It would be worth it to give it a try. There's more to the car than what we can put into words.
---jps
RevMeHarder
Jun 1, 2026 02:30 PM
Mxttz0r
Jul 5, 2019 03:19 AM
uZu
Dec 30, 2015 12:35 PM
ndamix
Sep 18, 2015 03:04 PM
Ajcmay92
Aug 31, 2015 01:21 PM
