2,000 miles - CEL - Bucking @ 4,000rpm & 6,000rpm - No Power
Old Nov 1, 2005 | 12:23 PM
Burnt Coil or Clogged CAT. with the CEL on im going with glogged CAT. the octane would not make the PCM make any timing adjustments unless there was knock. Call roadside assisstance and have them TOW the car to the Dealer. they always tow to the closest one and it wont cost you a dime or any embarrassment at losing an uphill race to a yugo.
How could you bring the loaner back late since you will be bringing it back to pick up your repaired car?
Old Nov 1, 2005 | 05:25 PM
or this,
happened to me recently.
https://www.rx8club.com/series-i-trouble-shooting-95/rx8-unable-grab-revs-5-6th-52522/
it got better, but no cel.
Old Nov 1, 2005 | 07:46 PM
rxeightr's Avatar
M0D Squad -charter member
I also suspect clogged cat, probably caused by an earlier flooding (prior to your ownership, of course).
Old Nov 10, 2005 | 11:28 AM
ZoomZoomH's Avatar
Mulligan User
congrats on getting car back fixed and healthy!!
Old Nov 10, 2005 | 03:51 PM
YZF1000R's Avatar
From: UK, Hemel Hempstead, 25 miles north of London
^ Same grats here . Thanks for posting too - it all helps us owners in the UK too.
Old Nov 10, 2005 | 04:32 PM
alright glad thats fixed
note to everyone who has a dealer that wont check their cat when we say so- make them read this thread
Old Nov 10, 2005 | 10:01 PM
rxeightr's Avatar
Welcome back to the ways of the 8.
Old Nov 12, 2005 | 04:41 AM
mikeb's Avatar
100% Italian
mine has a similiar issue
I was thinking it may be my K&N 2nd gen intake
but maybe its the cat
Old Nov 13, 2005 | 01:36 AM
Aratinga's Avatar
Mad as a wet hen
Originally Posted by Cool-Blue-Dad
...I actually found a damaged water hose on the day I brought it home. Almost looks like it was chewed. Anyone ever find rodent damage from storage (either by Mazda, a dealer or other private storage)? I guess I need to crawl through the whole car inspecting for more insidious types of damage that would have occurred during the year the car sat around....
Rats think RX-8 coolant hoses taste gooooood.
The Rat that Ate my 8
Better check for rat nesting materials in your airbox as well as going over all hoses and wiring to look for other signs of gnawing. Did the dealer replace your damaged hose when they replaced your cat?
Old Nov 14, 2005 | 03:05 PM
mikeb's Avatar
100% Italian
how long did it take to replace the cat?
Old Nov 15, 2005 | 01:22 PM
mikeb's Avatar
100% Italian
that is what I was afraid of
Old Apr 14, 2006 | 11:03 AM
czr's Avatar
czr
RX8 RX8!
Ok, I have a similar problem as above. It starts to buck under two conditions:
1. AC is on for a decent amount of time (doesn't matter what setting)
2. RPM Range is 4-6k WOT
The first time I noticed this was in last November when I had the AC pumping in bumper to bumper traffic car started to buck AND the Temp guage needle jumped to HOT. Took it in for service and I told them to check the CAT. They replaced the thermostat and said the cat was fine. Last month the same thing happened again but popped a CEL and took it in for service and they said the CEL was caused by a faulty gas cap which was replaced. What a joke. Same thing happened again 2 days ago. I am scared to go WOT with the AC. I would like to take it in again, but maybe someone else has had a similar problem with the AC on. This would be the 3rd time I take it for the same problem and I want to point these clowns in the right direction as I am wasting time. The car is absolutely perfect without AC
I am contemplating taking it to another dealership, but this dealer has great loaner cars and gives me one at every service.
I did some research from the below thread as well. TIA
https://www.rx8club.com/showthread.php?t=52522
Old Apr 14, 2006 | 06:43 PM
therm8's Avatar
Bummed, but bring on OU!
Sounds like the ecu going nanny on you for high coolant temps. The needle going hot, means it's extremely hot. The ecu will pull timing like crazy for high temps, and there goes any power. The A/C on connection, lends credibility to this theory, as the car will run hotter with it on, particularly without airflow through the condensor and radiator.
Edit: btw, overheating a rotary engine can quickly lead to its failure, so I'd recommend not using the A/C until you get the problem diagnosed/fixed. If you have access to a canscan device, you can watch your coolant temp in real time.
Old Apr 15, 2006 | 04:45 PM
czr's Avatar
czr
RX8 RX8!
Any ideas on what I should tell the dealership to check out? I will be going to a different dealership. Either it's not getting enough air or not enough gas. Maybe the ECU is cutting gas? BTW, they reflashed my ECU last time I was in there.
Old Apr 19, 2006 | 03:58 PM
clukas13's Avatar
I have the same problem & for sure that u have a cloagged cat
Old Sep 21, 2006 | 11:33 AM
csuttman's Avatar
From: Jupiter, Florida (sure beats Wisconsin winters!)
How long does it take from the time you notice the car is sluggish the the time it is so bad the dealer will replace it?
Mine has been slugish off and on for a couple months now. I took it in a few weeks ago and they replaced some plugs and re-flashed it, but said the cat was within specs. It ran fine for about 300 miles, then got sluggish again. I'll be bringing it in again soon, but want to know ahead of time if I'm noticing the beginning of the end of the cat... or if it's something else.
