How far off is my speedometer now?
Old Nov 1, 2005 | 08:13 AM
myfuncar's Avatar
I replaced the stock tires/rims with 17" wheels and taller than stock all weather (Blizzaks). While I was doing the switch, I laid a blizzak+wheel over a stock+wheel, the blizzak combo is about 1/4" bigger in all directions. In other words, when you stood them up next to each other on a level surface, the top of the blizzak combo is about 5/8" taller at the top.
Is my speedo reading faster, slower, or so close to the same that it doesn't matter? And what about the odometer?
Question # 2, since this combination is much smoother and quieter, and the tread on the original tires is getting thin, I'm thinking of leaving these in place all summer in '06. Bad idea? Pros and Cons?
Old Nov 1, 2005 | 08:16 AM
Critters's Avatar
Bigger wheels = more distance traveled per rotation, so your spedo will be slightly under the real speed. Same with the odometer. You could work it out, you know the diameter of each wheel, so you can work out the circumference, and then find out the percentage difference.
If the distance traveled / circumference was 10% more then the spedo would be 10% slower, well, that's what I think. Am I right?
Old Nov 1, 2005 | 08:19 AM
willhave8's Avatar
http://www.miata.net/garage/tirecalc.html
Enter your old tire size, new tire size and it will tell you the circumference differences as well as the impact on your speedo
Old Nov 1, 2005 | 08:21 AM
Critters's Avatar
Nice find
Old Nov 1, 2005 | 08:37 AM
willhave8's Avatar
There is a wealth of great info here === http://forum.miata.net/vb/forumdisplay.php?f=12
Old Nov 1, 2005 | 12:31 PM
myfuncar's Avatar
Great help! Wow. Thanks a lot. I'm off by about 1.2% - speedo reading too slow, but that's only about 1 MPH at 70, so I doubt it'll land me in jail.
Old Nov 1, 2005 | 02:22 PM
Dark8's Avatar
Ride Naked!
But it will be off 1.68 mph at 140 and that will land you in jail in most States.
Old Nov 1, 2005 | 02:40 PM
dazygirl415's Avatar
Very good find. Personally, I'm off by 2.7%, but I entered info for the average person running 20s and if I chose the right numbers, they're going about 15mph faster...
drebbrnator
Dec 27, 2018 07:02 PM
stickmantijuana
10
Oct 27, 2015 04:11 PM
dafiltafish
Aug 21, 2015 06:56 PM
SIllver
Aug 1, 2015 07:34 PM
PlayInMyWoods
Jul 27, 2015 08:33 PM
