What controls boost levels on a turbo setup?
Old Oct 27, 2005 | 01:36 PM
dmorales's Avatar
Spin Triangles! Spin!
I was curious what controls the boot levels? What I mean is how? ( the electircal/mechanical parts ) How does it work? I know you control by a boost controller that can be manual or computerized or what not, but how do they change boost settings?
________
Vaporizer
Old Oct 27, 2005 | 01:51 PM
MadDog's Avatar
Consiglieri
SC's work differently but for a turbo, if everything is working properly, then the wastegate controls the boost. The wastegate is a valve in the exhaust line that allows exhaust gasses to bypass the turbine blades. The valve is forced open when the pressure reaches a designed level. When the gasses bypass the turbine, pressure is relieved or maintained. You can use a boost controler to alter the pressure signal that raches the wastegate actuator to increase the pressure required to open the wastegate. The boost controller uses a second valve to control how much of the pressure signal actually reaches the wastegate actuator, thereby increasing the boost pressure required to open the wastegate.
Old Oct 27, 2005 | 02:02 PM
dmorales's Avatar
Ok, thanks.
So the wastegate would be situated between the exhaust header/manifold and the turbo itself, or at least incorporated in piping leading to the turbo?
________
LIVE SEX
Old Oct 27, 2005 | 02:20 PM
Asmoran's Avatar
between the turbo and the intake
Old Oct 27, 2005 | 02:27 PM
MadDog's Avatar
Consiglieri
^you are thinking of the blowoff valve. There are no exhaust gasses between the compressor and the intake....
Old Oct 27, 2005 | 02:31 PM
MadDog's Avatar
Consiglieri
Originally Posted by dmorales
Ok, thanks.
Yes, sometimes. Sometimes it is built into the turbo housing itself.
Old Oct 27, 2005 | 03:04 PM
dmorales's Avatar
Thanks MadJDog. :D
________
Medical Marijuana
yurcivicsux
192
Sep 12, 2017 10:54 PM
05rx8mazda
Nov 28, 2015 09:42 AM
yankeepicker
Sep 11, 2015 05:42 PM
