Rotors and brake problems
Old Oct 6, 2005 | 04:26 PM
KITRX8's Avatar
Can anyone tell me if they have had problems with rotors worping and what is the term TSB mean.
Old Oct 6, 2005 | 04:43 PM
Coop '04's Avatar
DELIVERED 07-17-2004
Yes lots of people have had warped rotors.
TSB means Technical Service Bulletin, which means a known quality issue that Mazda will fix for you, not the same as a recall which is usually a safety issue.
Old Oct 6, 2005 | 05:05 PM
Dragonrider's Avatar
Of the Black Dragon
Exclamation Brake Rotors Warping
At first I would say I had the same problem till I was directed to some experts on the issue of disk brakes.
Turns out that the rotors are not warping as I was originally informed but that brake pad material had build up on the rotors after hard braking on the track. They had some very useful recommendations to minimize pad residue build up on the rotors.
They did say that if the build up gets hard, the only real way to get it off is to have the rotors turned. While not overly expensive a bit time consuming.
That information saved me thousands, because I was getting ready to get special performance rotors that claimed to resist warping only to find out that the term was misapplied to the challenge that was really caused from bad material build up on the rotors.
I will try to find the tread where I got the info and post in later.
Old Oct 7, 2005 | 10:05 AM
Dark8's Avatar
Ride Naked!
Here is a good one: http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Old Oct 9, 2005 | 03:45 PM
Of the Black Dragon
Thumbs up That's the One
Originally Posted by Dark8
Thanks, that is the link I was referring to.
xAgyex
Jun 3, 2026 03:47 PM
ktec
Jun 26, 2021 10:18 AM
seb16
Sep 15, 2016 12:20 PM
J2daG1990
Series II Wheels, Tires, Brakes & Suspension
Sep 24, 2015 09:20 AM
T_Mags
Sep 3, 2015 11:40 AM
