Transmission Damage
Old Oct 5, 2005 | 08:33 PM
yiksing's Avatar
the giant tastetickles
Transmission Damage
If u rev-match downshift, the blip wasn't enough for the shift. Are you destroying the synchro, the clutch or the gears in the transmission?
Old Oct 5, 2005 | 08:51 PM
QBallz's Avatar
It's hard on the clutch and gears. Syncros are only used to sync the layshaft with the driveline.
Old Oct 7, 2005 | 02:33 PM
tuj's Avatar
tuj
I think you're asking if erroring on the lowside of the revs while rev-matching will cause any problems? The answer is not really. When you let out the clutch, the engine basically gets forced up to speed. Yes, this puts some stress on your driveline and your clutch, and no, it doesn't affect the syncros at all.
Its generally better to error on the high-side of the revs when rev-matching as that extra engine speed will bleed off quickly.
Old Oct 7, 2005 | 07:19 PM
yiksing's Avatar
Thanks for the feedback, I was kinda worried I might destroyed the gears while getting used to heel and toeing in the car.
92trbolzr
May 18, 2025 09:04 AM
Jst4fun
Apr 17, 2021 07:43 AM
airlive
Jun 28, 2020 07:46 AM
