Killed battery
Old Sep 25, 2005 | 10:08 PM
ptiemann's Avatar
Killed battery
Always something to learn. After my car had been rear-ended, I stopped driving it Monday, had it sit in the garage waiting for the body shop to have the parts.
Today I noticed the battery is dead.
As I wrote in the other thread, the trunk doesn't close anymore and that tiny bulb actually drained my car's battery in under 6 days.
<shrug>
Good I've got a 2nd car to jumpstart it. The bulb comes out easily too.
Old Sep 26, 2005 | 06:35 AM
Go48's Avatar
<shrug>
Yup, removed that bulb a long time ago in case the trunk doesn't get shut tight. The light is worthless anyway if you have the spare tire mounted in there.
Old Sep 26, 2005 | 05:58 PM
V_for_velocity's Avatar
One more couldn't hurt
From: Saskatoon, SK -- go to Winnipeg then head west
Took the light out too. The keys are usually in my pocket and the trunk opener was always getting pressed by coins and whatnot. Newest key has been reprogrammed to prevent this, I understand (longer button press required).
Old Sep 26, 2005 | 08:13 PM
beachdog's Avatar
The battery was probably drained in under 24 hours. You just didn't notice for 5 more days. My 8 is my weekend car. The normal parasitic losses will kill the battery in 7 days.
Old Oct 4, 2005 | 07:47 AM
nc-hoosier's Avatar
"The Angel Within"
Unhappy trunk light got me too....
Just got back from a 7 day vacation. Went to start my '05 Shinka and it was dead, dead, dead. Upon further examination the trunk wasn't shut.........
Had it towed to the dealership and am just waiting to hear from them. I miss my car already...........
I am taking out the trunk light as soon as I get it back!!!!!
Old Oct 4, 2005 | 07:55 AM
Go48's Avatar
Did that! You also might consider asking the dealer to replace the puny OEM battery with something a little more robust. (There is a service bulletin on this.) I installed an Interstate MTP-35 after a few months and when I haven't driven the car for an extended period, I periodically connect a maintenance charger to the battery to bring it back up to full charge. (I have other wheels so the RX-8 does not get out very often. It's basically our long-distance car.)
Old Oct 4, 2005 | 07:36 PM
SickestRx_8ghini's Avatar
RX_8Ghini
same problem here guys, whenever i take my car for tune up and if it takes more than two days, the battery dies. It sucks, so i changed the battery and now it works perfect, The Air conditioner also works better, it doesn't blow out hot air while you are on a stop light or idiling.
Old Oct 5, 2005 | 09:17 AM
DarkBrew's Avatar
Extraordinary Engineering
Alarm system to the rescue?
I locked my RX8 with the alarm tranceiver and it indicated that the trunk was open. I didn't even notice because it was barely up from its normal position!
Old Oct 5, 2005 | 05:31 PM
rxeightr's Avatar
M0D Squad -charter member
I have had my RX-8 sit for a solid month, and it started up just like normal.
Old Oct 5, 2005 | 05:46 PM
RotrDoc's Avatar
From: I've shaken off the sands of SouthWest Asia and returned to Houston and Gulfport, MS
I've occasionally driven a fair distance with the trunk unlocked. It needs a spring to pop the lid open when it unlocks, so there's no doubt.
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
Evan Gray
Sep 26, 2015 12:30 PM
