Clutch problem. Possibly the throw-out bearing.
Old Sep 22, 2005 | 02:58 PM
TORacing's Avatar
If you put my car in first gear with the clutch pedal totally pushed in and rev the motor to about 7000 rpm, the car will pull forward! While I had the car at the track this weekend, I tried launching the car at 7000rpm and burnt the **** out of the clutch because while I was sitting at the light the cluth was partially engaging. My friends and I think it's the throw-out bearing what do you guys think?
Old Sep 22, 2005 | 03:14 PM
Georgia8er's Avatar
Are you sure the clutch is not partially engaged all the time? And also does the problem only appear in first gear (even though your gear shouldn't affect this) and at high rpm?
Old Sep 22, 2005 | 03:20 PM
TORacing's Avatar
It's possibly but I don't smell it burning and it only pulls forward at 7000 rpm. When I launched it at 5000 I had no problem.
Old Sep 23, 2005 | 11:00 AM
TORacing's Avatar
anybody have any ideas or thoughts?
Old Sep 28, 2005 | 07:51 AM
cshlin's Avatar
maybe because it's so lightly engaged that at 5k you won't notice the pull? :x
Old Sep 28, 2005 | 12:02 PM
TORacing's Avatar
So what should I do?
Old Sep 28, 2005 | 08:40 PM
Ericok's Avatar
Rotary Wanker
It's not the throwout bearing, the clutch is not properly adjusted - although, by now, it may be too late. If it was making a noise when your pressed the pedal or was chattering during engagement, then it could be the throwout bearing.
Old Sep 28, 2005 | 08:46 PM
TORacing's Avatar
It does do exactly that.
Old Sep 28, 2005 | 08:47 PM
TORacing's Avatar
Originally Posted by djseto
I would stop posting because when you go to Mazda to get this fixed, they are gonna say F.U. and use this board to prove you are "abusing" your car.
It's too late for that, my warranty has been voided for a long time.
Old Sep 29, 2005 | 05:22 PM
ASH8's Avatar
Super Moderator
I agree, its adjustment.
So, dropping (sorry, launching) the clutch at 7000RPM and burning the **** out of it is no form of abuse? What a FH!
Old Sep 29, 2005 | 10:44 PM
TORacing's Avatar
Why would it act up now after 27,000 miles? I didn't drop the clutch, it did this with the clutch fully engaged, and I never said that it wa or wasn't abuse. What is "FH"? I spoke to a local mazda service shop (not a dealer, this is the only guy I would trust with my car) he says it sounds like the pilot bearing, trust me this guy knows what he's talking about.
Old Sep 30, 2005 | 03:07 PM
Ericok's Avatar
Rotary Wanker
You still have to disconnect the driveshaft, remove the transmission and remove the bell housing to get at the throwout bearing. While you're in there, you might as well replace the clutch (it's only one more step - remove the pressure plate; which, by the way, has the spring attached). Personally, I'd at least try adjusting first. It's WAY cheaper.
Old May 20, 2007 | 10:34 PM
Cromax's Avatar
Buzz Buzz Buzz
Mazda put flexi-pipes which break on the clutch line (for a good reason) and considering it is a hydraulic clutch, have you checked your fluid level to see if you're losing any fluid? I had that happen on my other car (not the RX8) a couple of years ago ... the clutch started dragging, and eventually the clutch pedal didn't work (due to the crack in the pipe getting too large to hold pressure).
Old May 21, 2007 | 07:03 AM
Cromax's Avatar
Buzz Buzz Buzz
Whoops ... sorry guys, this thread came up in my recently posted list for some reason.
WranglerFan
May 31, 2022 07:51 AM
Frosty8
Sep 11, 2015 10:27 PM
br0wm
Sep 10, 2015 07:50 PM
GARCIAC951
Sep 10, 2015 07:17 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
