Remote Start Help
Old Sep 19, 2005 | 05:36 PM
MyKey's Avatar
Remote Start Help
hows it going guys, This is my first post. Ive been looking around this site for a while getting some good idea. I tried a search but came up with nothing. I have a DEI remote start system i want to install but i was hoping some one could post a wiring diagram of the cars ignition system and anti theft security system. If not i guess i will have to go pick up the wiring diagram book from the dealer. I have a 2004 rx8 manual with all options if you need that info. Thanks for the help!
Old Sep 19, 2005 | 06:19 PM
rled's Avatar
5Picker
Remote start
Don't think you can install remote starting on a manual trans.
Old Sep 19, 2005 | 07:37 PM
MyKey's Avatar
You def can. I've seen people on this site that have got it done before, clutch needs to be bypassed which i already did, car now starts without pressing on clutch,. other then that ignition should be exactly the same
Old Sep 19, 2005 | 07:58 PM
staticlag's Avatar
The Professor
check out this diy
https://www.rx8club.com/showthread.p...t=remote+start
Old Sep 19, 2005 | 09:12 PM
zoomzoom_8's Avatar
also check out my diy on turbo timer install as it disables the key sense to allow the alarm to be armed while the engine is running which may also help too.
Old Sep 19, 2005 | 09:29 PM
lurch519's Avatar
www.evoperform.com
remote start can definately be installed on a manual transmission, but you wont find very many shops to put it in for you for liability reasons. as to going to a car audio shop and getting the wiring colors for installing an alarm and start, they probably wont give it to you either, unless you are friends with someone that works there, as there is the liability of giving out the info, as you can use it to break into a vehicle and disable the security system. as to bypassing the chip in the key, you need a DEI 556U, and you need to put one of your keys into this so the remote start will work.
Old Sep 19, 2005 | 10:01 PM
formatsee's Avatar
i can get you the wiring colors.
this is for the 2004 rx8
Old Sep 19, 2005 | 10:04 PM
lurch519's Avatar
www.evoperform.com
^^you got ballz my friend. hope directed doesnt catch u doing that.
Old Sep 20, 2005 | 07:07 PM
MyKey's Avatar
thanx formatsee ill try and do the install this weekend, shouldnt be to hard. let you know how it went
Old Sep 21, 2005 | 10:11 AM
devoid's Avatar
My doctor prescribed RX-8
Personally I'd let an installer do it for you...but hey that's just me.
As for remote start on a manual RX-8, I have it on mine. It's actually very safe on the RX-8, because the car has a nuetral wire, meaning, the car knows when the tranny is in gear or not. So first you tie into the e-brake, and then you tie into the neutral wire. If no e-brake, don't start, if e-brake, check nuetral switch...you get the point.
Old Sep 21, 2005 | 08:23 PM
MyKey's Avatar
I think i can handle the install. I am going to check how much they would charge to install i do have all the parts, if its not to bad ill let them. I could use alittle less headaches on the weekend after working on BMW's all week. And let me say they suck!! But if its kinda crazi ill do it myself, but thanx for the points about the ebrake and being in gear
Old Sep 21, 2005 | 09:09 PM
lurch519's Avatar
www.evoperform.com
where is the neutral safety wire on the mt 8, what color and where at. i would like to know
Old Sep 22, 2005 | 04:32 AM
lazi's Avatar
drivelinestore.com
i have a remote starter for my rx8 manual. my friend did it for me. but u won't find many shops who will do it for you.
Old Sep 22, 2005 | 11:33 AM
devoid's Avatar
Nuetral switch!
File Type: pdf
Old Sep 22, 2005 | 05:48 PM
lurch519's Avatar
www.evoperform.com
devoid, you are the man!!! im gonna check this out, and if it works :D
Old Sep 22, 2005 | 05:54 PM
lurch519's Avatar
www.evoperform.com
btw, where is said connector located. i hate the shop manual as it doesnt really give me precise location
Old Sep 22, 2005 | 07:33 PM
rled's Avatar
5Picker
remote start on manual trans.
Well now that I know you can do it,is there any brand of remote starters that is preferred ? I would love to put one on my 8. Thanks
Old Sep 22, 2005 | 08:04 PM
lurch519's Avatar
www.evoperform.com
viper/python/clifford. all made by dei, all good.
Old Oct 1, 2005 | 05:24 PM
lurch519's Avatar
www.evoperform.com
Old Oct 4, 2005 | 11:34 PM
irfan's Avatar
ElusiveSasquatch
for that chart.. are those DEI harness colors or rx-8 wire colors? i haev a diff brand system
Old Oct 5, 2005 | 08:02 AM
lurch519's Avatar
www.evoperform.com
those are teh rx-8 wire colors as provided by dei
Old Oct 10, 2005 | 08:24 PM
irfan's Avatar
ElusiveSasquatch
thanks for the diagram.
i have a Q... where in the engine bay is the neutral switch located? the diagram gives a general idea but with all the junk in that area id like a more precise area to look for the harness.
Old Oct 10, 2005 | 09:26 PM
lurch519's Avatar
www.evoperform.com
i found it, it is about 6 to 10 inches to the rear of the car from the shifter location. there are 2 grey wires that you should see, one will test constant ground, the other will only test ground when the transmission is in neutral. you can also get the wire at the ecu, but i didnt really want to run another wire into the engine bay.
Old Oct 10, 2005 | 09:40 PM
irfan's Avatar
ElusiveSasquatch
ok thanks, i'll pop the center console off tomorrow and takea look. are they both plain gray? neither has a stripe or anything?
Old Oct 10, 2005 | 09:46 PM
lurch519's Avatar
www.evoperform.com
no, no stripe. i apologize, but i wasnt exactly clear there. they are located under the car, right on the transmission. i jacked up the car, and located the wires. then i ran the neutral safety input wire (this is for a dei alarm, so it may be different for your compustar) to the wire by taking the 4 bolts that hold the shifter boot down, lifting that up, and feeding the wire down and back.
