19" offset question
Old Sep 15, 2005 | 10:34 AM
8DZ's Avatar
8DZ
19" offset question
I am looking at a set of Volk 19" GTC's with the front 19x8.5 with an offset at +47(face 1) and the rear is 19x9.5 with an offset of +49 (face 2). I was wondering if these offsets will work and what size of tire would be recommended? I have done a search & found nothing regaurding my question, any help will be appriecaited.
Old Sep 15, 2005 | 11:34 AM
KYRX8's Avatar
they should fit perfect. I would do something like a 245/40/19 in the front and a 275/35/19 in the rear, that will keep the overall tire diameter within 1/10 of an inch front and rear
Old Sep 15, 2005 | 12:06 PM
Fanman's Avatar
Actually they might not. I had a 19' x 8.5" with 38 mm offset & I had to put a spacer on it as the front rubbed the caliper. Rear was +35mm offset & it worked fine. You should definitely check as I think you may be scraping the caliper in both cases. I would go 245 & 275 setup, but only if you have not dropped the car more than 1" If you have they will rub. Also the sidewall height should be 245/35/19 (fronts) & 275/30/19 (rears). 40 & 35 would be for 18" rims & would be too tall if you are looking at 19" rims.
Old Sep 15, 2005 | 12:08 PM
Im_DANomite's Avatar
I love GOOOLD
it won't look good. you won't have a lip.
Old Sep 15, 2005 | 10:37 PM
punishr's Avatar
R u ready 2 get PUNISHED?
check my sig. for my wheel size and offset, if you like. They fit perfect with Tein S-Tech springs, no rolling, no rubbing.
nferguson88
Oct 6, 2015 12:45 PM
jer2911
Sep 29, 2015 06:37 PM
kody59
Sep 28, 2015 03:43 PM
Learners_Permit
Sep 27, 2015 07:38 PM
