Help! Where is the RPM signal pinout?
Old Sep 14, 2005 | 08:08 PM
SensaiDG's Avatar
I'm installing a S-AFC II but can't seem to figure out where I can get the RPM signal. For those of you that know the 8's PCM pinout codes please.. HELP!!
Old Sep 14, 2005 | 09:00 PM
https://www.rx8club.com/series-i-tech-garage-22/rx-8-technical-info-cel-codes-pcm-pin-list-collision-guide-26291/
Old Sep 14, 2005 | 09:16 PM
SensaiDG's Avatar
Thanks zoom44 for the reply.
I went through this thread but on your diagram is doesn't indicate the RPM signal directly. Is the information incorporated with some other component?
Old Sep 14, 2005 | 09:49 PM
staticlag's Avatar
The Professor
There is no RPM signal on the rx8
Old Sep 14, 2005 | 10:03 PM
SensaiDG's Avatar
no RPM signal? how is that possible?
Old Sep 14, 2005 | 10:14 PM
staticlag's Avatar
The Professor
to get the rpm signal from the ECU, you need to combine the signals from either both leading coils or both trailing coils, there is no straight RPM wire.
Old Sep 14, 2005 | 10:15 PM
staticlag's Avatar
The Professor
tapping one coil signal will give you 1/2 rpm signal. you need to add them together to get a full signal.
sigh, this is the second time ive answered this question today....
search button?
Old Sep 14, 2005 | 10:34 PM
SensaiDG's Avatar
Thanks for the help! I search for this info but the other posts were confusing. Your concise answer is much more easy to understand.
While I have your attention, what about the knocking signal? Only the PCM pinout diagram it has 1T, 1F, and 1G coming out the knocking sensor (KS). Which one should I use or will I have to combine connections like the RPM case?
Old Sep 15, 2005 | 01:17 AM
staticlag's Avatar
The Professor
Off the top of my head I havent needed to deal with the knock sensor,...
I would have to look at the service manual to answer your question...
If you have access to the manual it should be fairly easy to find.
Maybe someone else can chime in
Old Sep 20, 2005 | 10:57 AM
cardoc01's Avatar
The Doc is in
ck out my post about hud
Old Sep 20, 2005 | 12:01 PM
dodo_croatia's Avatar
jump...
# GReddy e-manage RPM Signal Extraction Adapter #3 - #15900909 ONLY $19*
(For Mazda RX-8)
# For extracting the RPM signal from Mazda RX8
# Wire in to each of the ignition signals on the ECU side as well as to the ground.
http://www.mohdparts.com/emanage/spe...pter_3_pic.jpg
http://www.mohdparts.com/emanage/index.htm
mdl0209
May 23, 2019 05:46 PM
D13
Oct 1, 2015 07:55 AM
tommy26Germany
Sep 29, 2015 10:33 AM
