help!! installing brake pads
Old Sep 2, 2005 | 12:30 PM
epitrochoid's Avatar
Riot Controller
Exclamation help!! installing brake pads
Alright, well I've got to install new pads before I go to the dragon next week. Problem is, they wont be here until Tuesday due to the holiday, and I leave at 5:30am Wednesday. Now I've changed brake pads before on other cars, and it's a pretty straightforward process, but I just want to make sure I have all my bases covered:
Am I going to run into any problems with just a decent socket set and an impact wrench in my toolbox?
Do I need shims, spacers, brackets, lube of any sort?
Has anyone else run into any complications doing this?
Any help would be appreciated, as I don't want any delays in leaving for NC next week...better yet, I dont want to find out I didn't install the pads correctly while I'm flying towards an ungaurded cliff at some ludicrous speed. They are Hawk HPS btw, both front and rear sets.
Old Sep 2, 2005 | 12:37 PM
Brice-RX8's Avatar
I think this might help you out, since I have not had to do a pad change on the 8 yet.
http://www.hi-impact.org/ryang/modify/modify.html
Look down towards the bottom there are DYI instructions for quite a few things. Great resource.
Have fun in the mountains!!
Old Sep 2, 2005 | 01:00 PM
BlueRenesis82's Avatar
Registered Tracker
you will need a tool for the rears to rotate the piston back into the caliper
Old Sep 2, 2005 | 01:11 PM
StealthTL's Avatar
Calipers......
Fronts are REAL easy, loosen the bolts, but leave the top one in place - lift frontwards to free the pads, you might need to push the piston back in a little (just use two thumbs) slide the new ones in and bolt up.
But stuck is what you'll be without one of these little beauties to "screw" the rear piston back in......
S
Old Sep 2, 2005 | 01:42 PM
tuj's Avatar
tuj
No, use a needlenose pliars on the rear screws. You can hold the pliars open about 1" and put the ends in the slots and rotate the screws. They turn pretty easily, so its not bad at all.
Old Sep 2, 2005 | 01:43 PM
tuj's Avatar
tuj
https://www.rx8club.com/showthread.p...ight=diy+brake
Old Sep 2, 2005 | 02:08 PM
Riot Controller
i have a caliper compressor..so i should be cool there. thanks the help guys!
Old Sep 2, 2005 | 02:39 PM
StealthTL's Avatar
That's my point......
....caliper compressor WILL NOT work, you need the little tool above. (or, as suggested, you can ruin a perfectly good set of needlenose pliers, too )
S
Old Sep 2, 2005 | 02:51 PM
Registered Tracker
S
Yep, I bought one of those
Old Sep 2, 2005 | 04:42 PM
staticlag's Avatar
The Professor
S
Just stop by autozone and get the tool, I think its like $16(Or its $7) but its less than $ 20 for sure. It makes life so much easier. You will need a 3/8" extender that is greater than 6" to use it.
When I did one caliper with the needlenose I ended up making dents in the soft metal of the caliper. Now my rx8 is sad
Old Sep 2, 2005 | 07:39 PM
Riot Controller
yea..i have bad luck with pointy metal things
ill get the tool..i didnt know it was readily available
Old Sep 2, 2005 | 07:48 PM
olddragger's Avatar
good info thanks. I have 23000miles, 5 track days and one autocross on mine so i figue i better change them before i go to the track again in 3 wks!
olddragger
Old Sep 2, 2005 | 09:27 PM
Registered Tracker
i got the snapon one for $14
Old Sep 3, 2005 | 01:17 AM
Riot Controller
i cant seem to find the tool on the AZ website...does anyone have part number?
Old Sep 3, 2005 | 02:16 AM
staticlag's Avatar
The Professor
just goto the store in real life, its there.
Old Sep 3, 2005 | 05:42 PM
Riot Controller
alright, ill go by there tomorrow. thanks
Old Sep 4, 2005 | 01:18 AM
olddragger
How in the hell do you get 5 track days out of your brakes? ?
Are you sure you use them? I'm lucky to get two with racing pads.
Old Sep 4, 2005 | 09:49 AM
olddragger's Avatar
Yep, i use them. Just ask the guys! All track days so far where at Road Atlanta and it has some fast straights that you go from approx 125 down to 50-60. One thing is you have to do is let the brakes cool. AT RA there are places that can be done. It is also better to late brake so the time the pads are actually on the rotors is diminished therefore giving them more time to cool. Heat does affect wear.
RA is also a track that you can use 3nd gear a lot so the engine can be used to slow the car some. Really on RA for me there are only 3 turns that the brakes have to be used hard for any big drop in speed. Turn 6, turn 10 (oh my god!) and turn 1. The rest are not that hard on the brakes.
However for the upcoming event of 2 track days at Roebling I have ordered some carbotechs panters for the front and bobcats for the back. Been communicating with DPE (by the way a really great vendor, very helpful with their experience on the track with the 8 and unbelieveable service---- seriously) and I am going with their recommendations. I will swap out the fronts for some bobcats for street use.
olddragger
Old Sep 4, 2005 | 06:26 PM
Registered Tracker
interesting, my pads have been good for more than 2 track days as well running at Road America.
Old Sep 4, 2005 | 07:59 PM
olddragger's Avatar
Oh yea Razz, racing pads wear faster than oem
od
Old Sep 4, 2005 | 09:23 PM
AndyV's Avatar
Lurker
I was curious.
Disc Brake Piston Tool
Sears part #00946344000
Old Sep 4, 2005 | 10:01 PM
Registered Tracker
^thats it
Old Sep 5, 2005 | 11:19 AM
Riot Controller
yea i just went to the tools section at autozone, and it was right there. thanks for postin the picture, I probably never would have found it. its called a Disc Brake Piston Tool
Old Sep 5, 2005 | 12:41 PM
staticlag's Avatar
The Professor
Old Sep 5, 2005 | 01:42 PM
priscilla ls1's Avatar
Basic tools a hammer and a c-clamp you will need these. I use the hammer to knock the pads into place and The c-clamp to push the piston back into the caliper. Should take you about 10 mins
C-clamp does the same job and more and might even be cheaper.
