gas fill up problems
Old Aug 15, 2005 | 03:51 PM
Mikelikes2drive's Avatar
im left with a quarter of the tank and when i try to fill up my tank the gas stops pumping after about a gallon... i take out the hose try it again... still stops after a gallon.. did it about 4 times and stil the same result!
kinda frustrating and embarassing. is this a problem with my car? problem with the pump? anyone else have this problem? thanks :D
-Mike
Old Aug 15, 2005 | 04:14 PM
vapor lock on the pump. not your car. ive seen it happen before. unless you have tried more than one station/pump?
Old Aug 15, 2005 | 04:20 PM
wedge357's Avatar
ShinkaMan #748 SV6P
If the pressure of the pump is too great, backsplashing of gas onto the tip of the filler will cause the pump to sense that the tank is filled and stops it. Try pulling the filler out slightly or change the angle (turn it slightly sideways) to avoid this.
Happened to me a few time, mostly on interstate gas stations that are high capacity.
Old Aug 15, 2005 | 04:23 PM
that too
Old Aug 15, 2005 | 05:15 PM
Nubo's Avatar
Lubricious
There is a flap which is supposed to prevent fuel spillage in the event of a rollover accident. I know of one owner who had a fillup problem because the flap had somehow frozen in the shut state. If you have this same problem consistently at different stations this may be the culprit.
Old Aug 15, 2005 | 05:34 PM
its the pump...
Old Aug 15, 2005 | 07:38 PM
thanks :D everyone!
now i just got figure out where that knocking noise from underneath my car is coming from!
Old Aug 16, 2005 | 05:33 AM
Straight8's Avatar
lmao Your gas tanks have melted and become deformed. Recall time.
RevMeHarder
Jun 1, 2026 02:30 PM
GARCIAC951
Sep 10, 2015 07:17 PM
ed0128
Sep 9, 2015 04:50 PM
tgaffner
Sep 7, 2015 08:49 PM
titaneum_grey
Sep 6, 2015 10:21 PM
