getttin dyno'd today
Old Aug 13, 2005 | 02:58 PM
lurch519's Avatar
www.evoperform.com
Well, I finally got around to setting up an appointment to get my car dyno'd today, as I want to get a baseline number before I start doing some power adders (I should be recieving my AEM cai next week.) I am also going to be using Hymee's scanalyser so I can also get an idea of airflow and other things going on.
I will post results here later on.
Old Aug 14, 2005 | 11:24 AM
Mugatu's Avatar
Even My Dog Searches
so, how'd it go?
Old Aug 14, 2005 | 11:53 AM
cleoent's Avatar
n00b
how did it go? What flash are you on? Are you stock?
Old Aug 14, 2005 | 03:48 PM
lurch519's Avatar
www.evoperform.com
soooooooooooooooooooo mad!!!!!!!!!!!!!!!!
well, i am not sure what is going on, and i am very not happy with the numbers i put down.
to begin with, i have an 04 gt, bone stock, with 18k on the clock. i wanted to get some baseline numbers so i could get an idea of what each mod does for me. my first mod being the aem cai. as to flash, it is either p or r, not sure exactly as the service writer couldnt read the tech's handwriting, and i am not too worried about it as i am going to get reflashed next week with the first recall. (heat)
now, the shop i went to is car version 2.0, in wilmington, de, and they are a reputable shop, and one of my really good friends works there part time.
well, just as i get there, they are pulling out the civic hatch that they just dyno'd and had me pull in, and proceed to do set up (using a dyno pac). get me all set up, i make sure that dsc is disabled (press and hold for like 10 secs, make sure front wheels are straight) and off we go.
now granted, temp was pretty high, with a relatively high humidity as well. im not sure about humidity, but temp was about 100. now, i will let the numbers speak for themselves, but i seriously think something was way wront, as the n/a civic that was in before me posted about 160 hp.
lurch519's Avatar
www.evoperform.com
anyway, i am going to be talking to my friend that works there and see what he has to say about it.
Old Aug 14, 2005 | 04:47 PM
neit_jnf's Avatar
stuck shut 5 & 6 ports sleeves?
Old Aug 14, 2005 | 06:14 PM
lurch519's Avatar
www.evoperform.com
hmmm, might be a possibility, but i havent really noticed a lack of performance, i can still chirp 3rd on command, though if i remember correctly, they are vacuum actuated and they did have to hook up a vacuum line for the dyno pull
Old Aug 14, 2005 | 06:23 PM
cas2themoe's Avatar
PoloRican Rotary
Something's not right.............
Old Aug 14, 2005 | 08:12 PM
wedge357's Avatar
ShinkaMan #748 SV6P
that's a weird-looking power curve if I've seen one...
What gear did you run the dyno? Can't be that your torque curve ran downward with the engine rev???
Old Aug 14, 2005 | 09:04 PM
cleoent's Avatar
n00b
get a refund from the dyno, their **** is f*$*ed up.
Old Aug 14, 2005 | 10:19 PM
lurch519's Avatar
www.evoperform.com
i am pretty sure their dyno isnt f'd up, as they had just got done doing a couple pulls for an eg civic hatch that had a swap done, n/a, and that made like 160 to the wheels, either something wasnt hooked up right, calibrated right, or i have an issue with my motor. i am pretty sure i do not have an issue with my motor (at least as big as this would make it seem) as that same day i chirped 3rd with the ac running.
i gotta sit down with my friend, as he is a master mechanic for lexus, plus works there part time, and has a 350+ hp turbo eg civic and is going to be putting a full race kit on the car. i am sure that he will help me figure out what went on, and get me a much better price on subsequent dyno pulls.
Old Aug 15, 2005 | 09:06 AM
KYLiquid's Avatar
Oil Injection
very strange, but doesnt look like the power band from the dyno when the DSC is on, so it looks like its not the tcs/dsc problem they had with the early dynos..... very strange indeed. Did you get a wideband reading from this dyno...and what gear? Sounds like the car is running fine but the dyno just wasnt reading it correctly...almost seems like its off by 100hp
Old Aug 15, 2005 | 10:30 AM
what was this vauum hose they hooked up? they obviously did not dyno you vehicle correctly. do they have the raw data and also how did they get the rpm. i bet they had it set up incorrectly. see they get the ingition signal and then they have the software turn that into rpm. but they have to use the correct math. they probably used the math from the civic pull which would not be correct.
its a dyno not using the correct calibration for a rotary.
Old Aug 15, 2005 | 11:02 AM
r0tor's Avatar
first thought was its didn't get the right rpms... but the scale looks convincing
So either the load cell malfunction or perhaps you have the latest R flash and the some protection scheme in it makes the car dyno proof?
Old Aug 15, 2005 | 02:04 PM
wait is this a DynaPACK as in one that bolts to the wheel hub?
http://www.dynapack.com/
Old Aug 15, 2005 | 02:19 PM
lurch519's Avatar
www.evoperform.com
^^thats it
Old Aug 15, 2005 | 02:34 PM
cleoent's Avatar
n00b
zoom so what does that mean?
Old Aug 15, 2005 | 02:46 PM
KYLiquid's Avatar
Oil Injection
i know the dynapack bolts to the hubs and uses hydraulic fluid pressure to impose a load on the drivetrain and measure power. It should be a little higher since your not losing power to rotating the wheels and tires. That fits along with my guess that its off by 100hp even more. although thats just a guess, there is no scientific reason i think its off by 100hp..lol
Old Aug 15, 2005 | 02:50 PM
it means im going to have a conversation with them so i can understand why it would be that off. stay tuned
Old Aug 15, 2005 | 02:59 PM
lurch519's Avatar
www.evoperform.com
thanks zoom. mucho appreciated. i was also logging data through hymee's scanalyser, though i havent really looked over it too much. i can send you the entire log if that may help determine what is going on
Old Aug 15, 2005 | 03:06 PM
Mugatu's Avatar
wow that torque curve is, um, interesting
Old Aug 15, 2005 | 03:41 PM
hey corksport has a dynapack. ill email them.
Old Aug 15, 2005 | 09:21 PM
LiveToRev's Avatar
Bah! Who needs a redline?
I see that they are using the SAE correction method shown on the dyno graph. Are our cars rated using the SAE method from the factory as well?
Old Aug 18, 2005 | 02:20 PM
lurch519's Avatar
www.evoperform.com
:::::UPDATE::::::
I think i may have figured out the problem, read here.
https://www.rx8club.com/showthread.p...86#post1008486
Old Aug 18, 2005 | 02:49 PM
cleoent's Avatar
n00b
Originally Posted by lurch519
:::::UPDATE::::::
that doesn't explain in the slightest how you didn't notice you were missing 100hp...
