Exedy Twin Plate Clutch w/Flywheel
Old Aug 11, 2005 | 06:41 AM
smrx8's Avatar
I'M going to be buying a clutch and flywheel has anyone heard of this name brand EXEDY ????? vivid racing has this on ebay
Old Aug 11, 2005 | 06:54 AM
lurch519's Avatar
www.evoperform.com
to do a LOT of friction materials, brakes, clutches, etc
Old Aug 11, 2005 | 07:35 AM
Rx7Roadster's Avatar
My spoon is too big
Exedy makes good parts. They have been around for a while. Ive never heard anything bad about them.
Old Aug 11, 2005 | 07:43 AM
takahashi's Avatar
EXEDY has been racing for nearly decades in Japan. Have sold world wide. Japanese use that in their cars for a long time.
www.exedy.com.au www.exedy.co.jp
Good single clutch there. I am not sure they have flywheel for the 8
Old Aug 11, 2005 | 08:00 AM
Jason's Avatar
RX7store.net
Great clutch, but complete overkill for the RX-8
smrx8's Avatar
They have the combo clutch and flywheel might just pick it up right now its at 500 on ebay with a buyout of 1600.
Old Aug 11, 2005 | 08:02 AM
takahashi's Avatar
Nice. I don't think they are overkill. Single clutch is ok. Double carbon clutch maybe an overkill.
If you turbo then yes. If you change the flywheel, it is also advised by many tuners advise to change the clutch too.
smrx8's Avatar
Overkill in what way not enough hp ?? can you give me a quote on clutch and flywheel
Old Aug 11, 2005 | 08:07 AM
takahashi's Avatar
sm,
Racing clutch may kill the driviability in congested traffic.
It is hard to ride the clutch at slow speed. You may stall a lot of time.
That is all.
Old Aug 11, 2005 | 08:10 AM
smrx8's Avatar
Yeah the one on ebay is double ok ill do more searching
Old Aug 11, 2005 | 08:14 AM
takahashi's Avatar
Ask them what they think of it for city driving. They should be able to answer you.
In Japan, they only have single clutch. Since it is not selling twin plate carbon or triple plates for only 180 hp at the wheel. The single clutch has a torque rating that can handle a GReddy turbo too I think. I forgot what it was but I check it once and make sure I can change to a single clutch for the future FI.
Old Aug 11, 2005 | 10:03 AM
Psylence's Avatar
Back in the family
Twin plate clutch will have the added advantage of smaller clutch plates. Less rotational mass than one big single. Also spreads out the force more so a 2plate will also last longer. I would also assume that a twin plate will require slightly less pedal effort than a single plate of equivalent clamping force. Multiplate clutches include a flywheel as part of the deal too...
But it's total overkill for the RX8. The only reason to buy one is because it's trick and cool and you just happen to have loads of extra cash burning a hole in your pocket.
Old Aug 11, 2005 | 10:28 AM
army_rx8's Avatar
X-Sapper
the stock clutch and pressure plate on the rx-8 are made by exedy :D so you already have some first hand experience with one of their products
haha so all you have to do is slap on a sticker that says "EXEDY" on your car and be done with it
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
