Compression Test on engine with ~19k miles
Old Aug 9, 2005 | 08:05 AM
Jaguar_MBA's Avatar
My RX8 was in the dealership and had to have the fuel pump replaced. I have done compression tests before on my 300zx would report reading such as 130PSI #1, 135PSI #2 Cylinder.......but when they Tech did the write-up of the repair, he wrote the following section
"Run compression test on both rotors. Had 7.2 7.2 7.3 on #1 rotor cold and had #2 was 7.7 7.7 7.8 cold. Ran compression test hot too had marginal readings."
My question is what are these 7.2, 7.2, 7.3 numbers rated in... obviously not PSI?
What would a bad compression number look like using the above methodology?
Old Aug 9, 2005 | 08:32 AM
Go48's Avatar
If they had used the correct tool (WDS) and procedure to check the compression they should have reported reading from a screen similar to the attached WDS image. Apparently, they are using an older/different tool.
And what do they mean by: "Ran compression test hot too had marginal readings"? Are they suggesting that you had poor enginecompression? Time to consider consulting another dealer in my opinion.
Attached Thumbnails Compression Test on engine with ~19k miles-compression-test.jpg
Old Aug 9, 2005 | 09:21 AM
ZZ8's Avatar
ZZ8
Yada, yada, yada...
I took my used 2004 RX8 to a mechanic. One of the things they did was a compression test and here are the results:
Rotor #1 @ 212 RPM: 7.7/7.3/7.5
Rotor #2 @ 216 RPM: 7.6/7.5/7.2
They used a Mazdaspeed tool that is calibrated/certified every year.
Mazda minimum specification is 7.0 Kg/cm^2
Extrapolated to 250 RPM, the engine compression is over 8.0 Kg/cm^2
They told me that these numbers are very good.
Old Aug 9, 2005 | 09:33 AM
ZoomZoomH's Avatar
Mulligan User
if they used the old Mazda compression test tool (specifically designed for rotary engines), then those are very good numbers.
FWIW, for the older rotaries, at a minimum the compression numbers should be 6, so 7's are more than ok :D
Old Aug 9, 2005 | 09:36 AM
adrian-1's Avatar
Ex- member.
The unit they use is kgf/cm^2. Below are the specs on determining if its good.
8.5 standard, 6.9 minimum
1.5 difference in chambers and 1.0 difference b/w rotors.
Compression pressure (kPa {kgf/cm2 ,psi} [rpm])
Standard 830 {8.5, 120} [250 rpm]
Minimum 680 {6.9, 98.6} [250 rpm]
Standard difference in chambers Within 150 {1.5, 21.8}
Standard difference in rotors Within 100 {1.0, 14.5}
Old Aug 9, 2005 | 10:09 AM
yeah those are k numbers those are good
Old Aug 9, 2005 | 12:19 PM
Mazmart's Avatar
Jaguar,
The only figures they neglected to give you were the cranking rpms. These are vital because the readings are dependant on cranking speed like ZZ8 illustrated. This is what worries me when dealers are eager to replace a motor and they may not have the most experience and diagnostic skills as regards rotary engines.
Paul.
Old Aug 9, 2005 | 01:52 PM
true good point paul. thats one of the things i question abotu the engien replacements as well i.e.- did they do the comp test correctly?- we'll never know.
Old Aug 9, 2005 | 01:55 PM
priscilla ls1's Avatar
Your compression is right where it should be. Any lower and u are losing power and any higher and u would be damaging your internals, but over time of course. When he did the test did he remove the spark plugs and plug the hole with a pressure tester gauge, usually they do it with one and crank the engine and the dial will tell u how much pressure built up in the compustion chamber at TDC.
Old Aug 9, 2005 | 02:53 PM
Mazmart's Avatar
Old Aug 9, 2005 | 03:46 PM
What's that Paul?
Old Aug 9, 2005 | 04:48 PM
Mazmart's Avatar
I was just trying to figure what Priscilla meant by " Any higher and you would be damaging your internals", but I was trying to ask that ina slightly discreet way.
Paul.
Old Aug 9, 2005 | 04:56 PM
Paul.
It's cool paul,
U see compression can be bad if it is to high, I would rather have a car suffuring from low compression then compression that is to high because the inturnals of the engine are really at a strain. That is all I ment.
Old Aug 9, 2005 | 04:59 PM
care to explain Paul? popcorn anyone?
Last edited by zoom44; Aug 9, 2005 at 05:08 PM. Reason: previous message was too cheeky
Old Aug 9, 2005 | 05:04 PM
rxeightr's Avatar
M0D Squad -charter member
Extra butter on mine Zoom.
Old Aug 9, 2005 | 05:21 PM
hahaha very funny :D
But u know what I meant. Sure it is a rare case when compression is to high and if compression is low, well we all know what the problem is leak somewhere.
Old Aug 9, 2005 | 05:34 PM
Mazmart's Avatar
I try to keep my internal strain down through nutritional means, I guess it's probably similar.
Paul.
Old Aug 9, 2005 | 05:49 PM
Paul.
Funny guy? Anyways like I was saying, too much compression would cause a wide range of problems and a loss of hp and parts. U have to agree with that.
Old Oct 18, 2005 | 06:33 PM
IGOZMZM's Avatar
Zoom Zoom Member
Here are my compression results. I think they are very bad, but the dealership says that mazda tech line won't let them do anything until they can verify my power loss problem. Can anyone tell me how bad these numbers are if at all?
1ST ROTOR ........................2ND ROTOR......MAX MIN
CHAMBER 1 644 KPA.........599 KPA...........ROTOR 1 79.6
CHAMBER 2 723 KPA.........612 KPA...........ROTOR 2 22.5
CHAMBER 3 717 KPA.........590 KPA...........MAX ROTOR 1&2
...................RPM 217.........RPM 212..............111 KPA
Old Oct 18, 2005 | 06:39 PM
BOOSTD 7's Avatar
RX8Club.com Founder
I love the forum, hahaha!
Old Oct 22, 2005 | 01:31 PM
RX8 Brunei's Avatar
Rotary Lover
From: Brunei: Where Ricers show off their fugly rides
guyz, do i need to replace the engine when it had lost compression??
Old Oct 25, 2005 | 10:24 PM
Kewl's Avatar
Former RX8 Owner.
And just how will these compression reading change (lower to what level) if you live at 5000 feet.....not sea level?
Old Dec 27, 2005 | 05:24 PM
8is>enuff's Avatar
Bland
Just got a copy of my compression check and was wondering if anyone knows how to read it. It lists the following:
Rotor 1
657KPa. Chamber 1
704KPa. Chamber 2
652KPa. Chamber 3
264RPM. Engine RPM
Rotor 2
519KPa. Chamber 1
590KPa. Chamber 2
631KPa. Chamber 3
266RPM. Engine RPM
51.9KPa max. rotor 1 - min. rotor 1
112KPa max. rotor 2 - min. rotor 2
72.7KPa max rotor 1 - max rotor 2
Car is slow as molasses.
Old Dec 27, 2005 | 05:25 PM
8is>enuff's Avatar
Bland
Well, the compression check didn't say my car is slow as molasses - I added that part myself.
Old Dec 28, 2005 | 06:47 AM
Go48's Avatar
Rotor 1
657KPa. Chamber 1
704KPa. Chamber 2
652KPa. Chamber 3
264RPM. Engine RPM
Rotor 2
519KPa. Chamber 1
590KPa. Chamber 2
631KPa. Chamber 3
266RPM. Engine RPM
See the attached image for the shop manual page related to compression test readings. According to the manual, the ideal readings at 264-266 RPM should be between the high 800's maximum to around 700 minimum. The differences look OK, however. So, it seems a little strange to me that the absolute readings are not up to snuff, but the differences are well within spec. Smacks of a worn out engine with no single point failure. (Or a compresion test done with insufficient oil film in the rotor housings to provide adequate compression.)
Attached Thumbnails Compression Test on engine with ~19k miles-compression.jpg
